Question about Yamaha Portable Keyboard with 61 Touch-Sensitive Keys and General MIDI
Floppy disk drive
This refuses to acknowledge that a disk has some 28 tunes/accompaniments recorded on it. It went like this as I was scrolling up the numbers to get to the last tune first. It had been reading fine until then.
I thought I may have upset it's programming, would a reset of factory settings lose the stuf it came with? I have nothing of my own installed on it.
Jim
  • retsyl Nov 10, 2008
    Answered my own query in a way. It seems that doing what I did scrambled the management file on the disk. It writes to and reads from a freshly formatted floppy quite ok. I did risk the reboot by holding down the top white key (C) whilst powering up. I had nowt on there to risk losing anyway and it doesn't come with a boot disk.
  • 3 Answers
It needs no further fixing now.
I rebooted the keyboard as suggested by the FAQ then reformatted the floppy in the computer. I tried a recording which it then played back fine. It also acknowledged the title of the song as 001song as normal.
Thanks for the chance to air the problem though.
Posted on Nov 10, 2008
How to use floppy disc on Technics sx-gx7 organ
If there is no disk drive on the instrument, get a floppy drive with a midi out and use it that way.
Jun 30, 2017 | Music
I would like to record my own song without any pre-set chords, drums etc. Is this possible.
Please advise what model of keyboard you have purchased. Some do not allow recording without accompaniment. I might be able to help.
Dan
May 19, 2016 | Yamaha DGX-650-PortableGrand Digital Piano
Is there a head cleaning disk I can buy
the floppy drive never had a cleaning disk. if it doesn't work it can be replaced.
Feb 18, 2015 | Roland Boss BR-800 Digital Recorder
Turn off accompaniment?
go to the utility settings, accompaniment settings..turn off.
Apr 09, 2014 | Roland FP-80-Digital Piano
Floppy disk drive emulator usb
The floppies in most of the music instruments are NOT quite compatible with the USB floppie emulators.
Feb 20, 2011 | Korg Sound Card Disk O1w Fd 01wfd 01 W O1...
I have a disk not ready sign on screen, floppy disk receiver has being replaced three times; old and new floppy disk tested; cable has continuity... I do not know what else can be
The floppy drives of this age often required strapping to select the unit number and other setups. Newer drives were not compatible. Make sure the drive selected light remains on when power is on. If not, check the drive selections jumpers for the drive.
Feb 03, 2011 | Korg Sound Card Disk O1w Fd 01wfd 01 W O1...
The disk drive on my Yamaha Clavinova CVP-105 acts like it has a disk in it when it doesn't and won't always play pre-formated disks like it used to. Is the drive dieing? Where can I go to get it fixed? ...
Often these drives are continuosly selected by the controller and rotate even without a disk.
These USUALLY use the old 720K disks which are almost impossible to find. The common 3.5 1.44Mb floppies often will not work in these units.
You can SOMETIMES use the 1.44Mb disks by covering the second corner hole AND degaussing the disk with a tape eraser and then reformating the disk in the Clavinova.
The pre-formatted 1.44Mb disks without degaussing SOMETIMES leaves artifacts between the tracks used by the 720K disks that causes problems.
Nov 27, 2010 | Yamaha Music
Cannot use the floppy disk of my CVP 65 as it appears the memory is full. It plays new discs, but won't record.
This sounds like it MIGHT be a floppy drive problem rather than a full memory... REMEMBER to ONLY try recording a file no bigger than what the floppy will hold which is 720Kb.
NOTE: The disks used in this are not the COMMON 3.5 inch floppies, but the older 2DD 720K floppies. They have only one hole on corners where the new 1.44 Mb ones have two holes.
To USE the 1.44 Mb flopies do this: Use an opaque tape to cover the hole that does NOT have the write protect slider. THEN most omportantly DEGAUSS the disk with a degausser. THEN Reformat the disk in the CVP 65.
The pre-formatted 1.44 disk when formated at the 720Kb used by the CVP 65 will have ARTIFACTS between tracks since the higher density also have half the track spacing and the formatting doesn't always clean enough width leaving artifacts between the tracks when formatted as 720Kb These ARTIFACTS can cause trouble.
The 720Kb disks are ESSENTIALLY unavailable anymore.
Jan 15, 2010 | Music
Not reading my floppy disk( MPC 2000xl by akai)
Have you tried formatting the disc using your MPC 200XL?
Mar 20, 2009 | Music
Yamaha Portable Keyboard with 61 Touch-Sensitive Keys and General MIDI Logo
87 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
