Question about Nikon Coolpix 5400 Digital Camera
Camera will not power on as if battery is dead ,(not battery )was working fine
Camera was working fine, I was carring the camera in a cargo pants pocket, took it out to use it & it would not power on, I though the battery might have gone dead, recharged battery & rechecked opperation, still off. tested battery with a volt meter, ok.
  • dls1 Nov 11, 2008
    the on off button is a rotating toggle not a push button.
  • 95 Answers
Some cameras have a similar issue when the on off button gets stuck down caused by dirt or small sand particals tap on palm of hand in all axis and a cleaning with small amount of isopropal alcohol sometimes helps symptoms sound like need pro care/repair
Posted on Nov 09, 2008
Camera will power-up only when connected to DC
Have you checked the batteries to make sure they are still viable?
Oct 11, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
Battery dead...cannot get the cargo hatch open without power.
If you jump started and nothing happened then you have a poor connection or your jump leads were too small. You need welding cable size leads and heavy clamp to get the current to a dead car. Leads the size of straw won't do it. Get it connected properly and retry. Try connecting to the starter terminal, then open the trunk, then try from the battery end. A good home mech should be able to work it out.
Nov 03, 2015 | Cars & Trucks
I have a 2003 chevy cargo truck....my battery went dead due to leaving my back up camera on. Now the truck idles rough and stalls...it ran perfect before the battery went dead...could it be that the...
Make sure the battery is fully charged before installing it. Some manufactuers have problems with electronics working with a low charge.
You may be able to get a scan on your vehicle with a more advanced scanner like a Dealer uses. You will not get any readings with the built-in system unless a "check engine" light is on.
The onboard computer can be bypassed with a Dealer unit which directly communicates with the vehicle components. The Dealer computer directly reads the engine controls and a Technician can ask different questions through this hookup.
Yes, it is possible for the vehicle to relearn its operating perameters.
Also wire your backup camera to a power line that is shut off when the car is off. Some people use the backup switch or backup lights to power the camera.
Sep 02, 2012 | Cars & Trucks
I have a 2004 silverado. My cargo light isn't getting any power. My third light works fine and when i reverse the harness the cargo lights work. I'm assuming its in the wiring. Do the two wir
There should be 12 volts on the orange wire at the bulbs. The switch controls the ground side of the circuit. There should be 12 volts on the blue w/white wire at the switch. The switch will ground that wire and complete the circuit and the cargo lights will turn on.
to check the switch you would unplug it and check for continuity between the pins that the blue w/wire wire and black wire go to.
Feb 24, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
Nikon Coolpix 5700 was working fine, now it won't turn on. Batteries are fine, but camera just won't power up at all. No error message, nothing but a dead (black) screen. No idea why it won't come on--it's...
Two quick suggestions first is the battery chamber contacts clean make sure they are clean. Are you using a battery pack with rechargeable AA's ? if so check the battery orientation it only takes one out of place. If you are using the rechargeable battery I know you said the batteries were fine but make sure the power is up on the rechargeable. I've had it where I put a battery on charge knowing it was pretty well dead came back 5 minutes later and the light was green, took the battery of the charger unplugged the charger plugged the charger back in and put the battery back on the charge. It then completed its true cycle.
Jan 04, 2011 | Nikon Coolpix 5700 Digital Camera
My S9600 was left unused [batteries left in camera] for several months. Now it will work fine with the mains adaptor, but is completely dead when on battery power. Have tried new batteries [rechargeable...
Sounds like corrosion on the battery contacts. I have seen battery contacts with a thin, transparent coating that came from leaking rechargeable batteries- doesn't look like the usual green crud, but it stops electricity from getting through. Try giving the contacts a scrape- you will need a long thin screwdriver or something of the sort.
Dec 01, 2010 | Fuji Finepix S9600 Digital Camera
Camera wont turn on.
try replacing the battery. Check best buy, radioshack or other camera dealers for a battery. Possible deadcell battery. These lith-ion batteries die with no warning. If there is no change, the camera is defective!! hopefully htis helps
Jul 20, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Turn Signal replacement /Ac query
you can either take the colum assembly off and remove the 2 screws and wires holding it in place and it should come right out, new one from junk yard or a parts store will work fine
Jul 04, 2009 | 1987 Cadillac DeVille
Nikon Coolpix 5400 Digital Camera Logo
110 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
