Question about HP Deskjet D1341 InkJet Printer
Ink level I can not find out how to get my ink level. It used to show up when I printed something. NOw it does not.
  • 75 Answers
No problem go to control panel cfhoose printer option right click the  printer icon goto properties th printing preference go to service click the icon th u can check the level
Posted on Dec 01, 2008
Hp officejet 4620 does not print with starter cartridge
If printer is in warranty, demand for replacement.
1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
If levels are zero, go for new cartridges.
2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Canon pixma mx350 printer ink level shows exclamation mark about the icon
If you are using an ink refill kit (or buying ink that has been refilled, the ink level will not show accurately) also, if refilling yourself you must clean the pint area of the cartridge with alcohol before installation, and then run the 'clean print head' tools from you Canon menus.
I recommend buying Canon ink, at least for 1 in 4 refills to reset your ink levels.
Nov 20, 2013 | Canon PIXMA MX350 Wireless All-in-One...
Where do I go to find how much ink has been used
To check the ink levels from the printer control panel
1. Press Setup.
2. Press the down arrow button to highlight Tools, and then press OK.
3. Press the down arrow button to highlight Display Ink Gauge, and then press OK.
The product displays a gauge that shows the estimated ink levels of all cartridges
installed.
4. Press any button to return to the Tools menu.
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the ink cartridges appear.
Replace the ink cartridges
Apr 14, 2012 | HP Photosmart C6380 All-In-One InkJet...
Replaced T0603 magenta ink with brand new cartridge. Ink levels show its FULL. But when do nozzle print check, no magenta line will print. Trying to pring something with red clip art and can't get the...
Depending on when you last used your printer it may take a few head cleans before the ink prints. Print a nozzle check after each clean (uses minimal ink).
Also be aware each clean depletes your other carts as well.
Jan 09, 2011 | Epson Stylus C88 InkJet Photo Printer
When we do a fax test, we get clear print; when we try to print documents nothing appears, altho it goes thru all the right sound motions
Sounds like your colour cartridge is empty. Fax test will pull from black only but documents sometimes use a combination of colours in order to print out black. I suggest checking your ink levels - instructions for windows;
Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low Check ink levels
Mar 05, 2010 | HP Officejet 5610 All-In-One InkJet...
Ink shows empty when toner is not even close to empty
there is one thing that if you refill the cartriage and then use again then still ink indicator shows low ink as its' ckt is designed so.
there is no problem you can print easily.
your printer will show correct ink level when you put in new cartriage.
but remember one thing that if your printer stops printing and shows message on computer that no ink in cartriage ,, then you need to reset printer counter, (this resetting process is present in your printer manual)
so no problem in printing, it shows low ink because the circuit inside it is designed soo.
so that you purchase new cartriage.
(remember : you need to reset the counter , refer to manual)
Jul 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Show Ink Levels When Printing
Here is the weblink which has a clear graphical representation of how to check the ink levels:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01576082&cc=us&lc=en&dlc=en&product=1146331
Thank you.
Nov 24, 2008 | HP Hewlett Packard LaserJet 3000dn Printer
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP Deskjet D1341 InkJet Printer Logo
182 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
