Question about Whirlpool GHW9150 Front Load Washer
Electrical problem Machine will stop running through the cycle and display code F11. I push pause/cancel twice try to reset and then it shows code F dL. After repeatedly pushing pause/cancel button and control on button, the machine will reset. I must restart the cycle and it will work again and then stop later.
  • Anonymous Mar 14, 2014
    if I push the cancel button unit stops if I push it again the unit turns on
    if I push the cancel button unit stops if I push the cancel button again the unit turns on
    President:
  • 878 Answers
Teecee, F11 is a communication error between the main board and the motor control board. The main board is on top and the motor control board is behind the lower panel. Sometimes the harness to these boards become loose causing this error. You would have to get at them and reseat the connections. F dl has to do with the door lock mechanism. You might of just had the door open when you reset the machine. To get at the main board on top you have to remove the 3 screws in back for the top. It will then slide back and off. To get at the motor control board, you will have to remove the bottom panel. The board will be in the back. Catriver..post back.
Posted on Oct 25, 2006
WHAT DOES ERROR CODE f11 MEANS?
Resolution: Error code F11 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below. In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
Unplug or turn the circuit breaker off for 30 seconds.
Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
Press the Pause/Cancel/Stop button twice to clear the display.
Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
24 7 Locksmith Amherst Ny 716 200 1030 Amherst Ny 24 Hour Locksmith Car...
Aug 07, 2016 | Whirlpool Washing Machines
My whirpool dryer panel comes on but when you push the start button!, it clicks off and then displays the pf code.
PF is a Power Failure error meaning electricity has been interrupted to the machine.
Any electrical interruption to the machine such as a circuit breaker being reset or weather related power outage can cause a PF error code.
To remedy;
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button.
If you continue to receive the PF error code, the control board may need to be replaced
Apr 23, 2015 | Dryers
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    F11 error code
    The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
    Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
    The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
    Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
    I keeg getting the dreaded F11 anf DL code!
    Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
    Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
    Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
    PLACEHOLDER FOR ART
    To remove the error display, press Pause/Cancel twice.
    If Pause/Cancel does not work:
    NOTE: If the error remains on the display, then call for service.
    Take care
    Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
    F 11 code
    F11 is an indication of a communications problem.
    Communications cannot be sent correctly between the machine control board and the motor control board.
    Here are some possible causes:
    • Loose wire connection at either the machine control board or motor control board.
    • Machine control board failure
    • Motor control board failure
    • Door lock
    • Motor
    Error codes can be caused by a Power Surge or other electrical anomaly, attempt to return the washer to operation by following the Hard Reset procedure below.
    1. Unplug or turn the circuit breaker off for 10-20 minutes.
    2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
    3. Press the Pause/Cancel/Stop button twice to clear the display.
    4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
    Jun 17, 2010 | Kenmore HE2 Plus Front Load Washer
    F35 code
    Take care
    Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Error code f35 on my washer
    Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool duet wahsher
    PLACEHOLDER FOR ART
    please do not forget to rate and comment about your experience with fixya today.
    Aug 18, 2008 | Whirlpool Washing Machines
    Whirlpool GHW9150 Front Load Washer Logo
    224 people viewed this question
    Sal De
    Marvin
    Marvin
    jimorris77
