Question about Intel Motherboard
Gigabyte Socket A GA-7VA Bios update failure
Hi there!
I was trying to update the bios on this MB through windows xp using @bios.It found bios update F13.I choosed to update and then the computer suddenly shut down while the disk access led remained constantly on. Nothing happened for several minutes so i tried to reboot.Every time it does the same thing.I removed the battery for 30 secs and the power cable to reset the cmos but to no avail.What can i do?Is my mb dead?Can i flash the bios again with a floppy
Please help!
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
You can try to save the motherboard w/ a floppy, and if that doesn't work, go to gigabyte's website and request for an RMA. I made the same mistake in trying to update the BIOS through @BIOS after it updated, it assked for me to restart the pc, and when i did, the was nothing. All i heard were the fans. Nothing on the screen, and it obviously wasn't posting. So go to Gigabyte so you can get another one, and tell them there's a flaw w/ the application @BIOS. If by any chance you update the BIOS, try it w/ a flash drive under DOS. Good luck.
Posted on Nov 13, 2008
GA-7VTXE BIOS update
MAKE YOU SELF 100% SURE THAT IT IS THE RIGHT MODEL.
You can get the software here:
http://www.gigabyte.lv/products/page/mb/ga-7vtxe/download/bios
Or use this upgrade utility:
http://www.gigabyte.lv/products/page/mb/ga-7vtxe/download/utility
If you are not sure you can download and install a small program here:
http://www.cpuid.com/softwares/cpu-z.html
You may have to use a unzip program like win rar or 7 zip.
I wish you the best luck.
Feb 23, 2011 | Computers & Internet
I was traing to flash my bios on MB GA-7VA and fail !!!
> is there some way to put new BIOS?
Yes -- details are on Gigabyte's web-site.
> Is BIOS chip removable?
Yes -- but you'll need special hardware, a "ROM programmer" to load a new BIOS onto the chip.
Jan 20, 2010 | Intel Motherboard
Can not copy a part of XP OS file
Hi there.
Go here to Gigabyte support and download the BIOS update you need>>>>>
http://www.gigabyte.com.tw/Support/Motherboard/BIOS_List.aspx?Keyword=GA-P35-DQ6
Good luck and thanks for using FixYa!!
May 26, 2009 | Gigabyte GA-P35-DQ6 Motherboard
Gigabyte GA-MA790FX-DQ6 installation problems
Hi speedfreak44, during the installation of windows one of the drivers did not install correctly & windows registry is messed up.
The blue screen is a typical response from windows. Even though you're windows installed SP2, there are another 89+ updates for SP2. (A reinstall with-out a format is not advised).
Suggest you enter you're bios & disable ACPI. This one I know for sure will show up in windows device manager as a PCI device with no name. Try again to boot windows. If it still fails to enter in standard mode than a complete re-install will be required including a format. Personally I do not use windows XP pro/home w/SP2 CD to perform the format, (After receiving a blue screen).
I have found it is 98% better to use the software tools, downloaded from the Mfg's web site for you're hard drive. Use the bootable software (On a floppy or CD), to format you're hard drive. Most Mfg's hard drive software will allow you to change the cluster size up. Windows standard uses a 4kb cluster size & you loose far more hard drive space. With a 16kb you loose only the file allocation or FAT, which is normal.
Than using the Win XP CD/SP2 install windows, clean.
(No need to format).
When finished installing windows, load the Gigabyte driver CD & install the chipset & other CD drivers. Turn on windows firewall & update windows SP2. (ASAP), (Save SP3 update for later).
It is in the updates of windows to iron out software & hardware driver updates. Do not install you're antivirus software until windows has finished updating its self & you install any hardware updates also through windows update. (Continue to leave the ACPI disabled in bios until updating is complete).
You can enable ACPI, antivirus software & printer software all.
You will find some needed software will install during windows update. Like; Quad Core processor update. With either home edition or pro it is advised to install .Net framework updates 1 at a time & only restart when prompted by windows. Other wise click the refresh button & continue windows updating. (You can save the .Net framework updates for last if you wish). You're video card may need .Net framework 2.0 or better for installation.
I am hell bent on installing windows once & correctly the first time. I understand you want to get this baby up & running but take the time & run the hard drive tools/utilities. (It's worth it)!
Good Luck speedfreak44!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Please let me know if this got you're system running without the blue screens?
One last item. It's also worth checking the dates on the Gigabyte CD to Gigabyte's web site before installing other drivers. Including the chipset drivers. You want to install the newest drivers the first time around. Here is the link to you're Gigabyte GA-MA790FX-DQ6 motherboard main web site.
(Click on the link).
http://www.giga-byte.com/Support/Motherboard/Manual_Model.aspx?ProductID=2690
Mike
May 27, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Flashing bios
pull the bios battery for a few minutes and reinsert it , see if it comes back on.
Nov 08, 2007 | Gigabyte GA-8I945GMF Motherboard
Bios update
if you can use another pc and reinstall the previous bios flash it from floppy this should sort out the problem
or you can try and flash the updated one again if this fails
then you need to contact the manufacturer for a possible bios chip replacement
hope this helps !
Nov 05, 2007 | Gigabyte GA-7VA Motherboard
Intel Motherboard Logo
591 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
