Question about Zenith C27A24T 27" TV
Black box on screen
About 14 seconds after turning on my tv, a black rectangle covers most of the lower half of the screen. If I turn the tv off and back on again I can see the whole image (for about 14 seconds). This happens when watching tv or dvd. When changing channels the box will sometimes disappear for a few seconds. When fast-forwarding a dvd it will disappear until I resume normal play.
    President:
  • 3,130 Answers
On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu. Good Luck Ps Please dont forget to rate this thread.
Posted on Oct 25, 2006
SOURCE:
Toshiba big tv. Comes on fine nice picutre. about 10 seconds after turn on a "black rectangle" appears in the lower half of the screen
Chances are it's just the closed captioning is turned on and set for "text" mode. Use the remote to go through the caption settings until it's turned off and that should clear up the box.
I've written a tip that explains what's happened and how to take care of the problem.
Feb 24, 2010 | Toshiba 32A33 32" TV
Toshiba 32AF45 Black Rectangle Issue
go into your menu and find closed caption, someone has accidently set the closed caption mode to text, when the on screen display of channel or volume goes away the box appears. turn off the closed caption feature or switch it to something other than "text" mode, and your box will go away.
Apr 10, 2009 | Toshiba 32AF45 32" TV
Black rectangle on screen
The box you're seeing is the "closed caption' box. You need to use the remote and disable CC mode on it, and the box will go away :)
Jan 20, 2009 | Disney 13" TV
Black rectangle on bottom half of screen
captioning on turn off with remote.
Nov 12, 2008 | Zenith B25A02Z TV
Black box covering one-half of TV screen
Try turning off the text box function of the closed captioning.
Aug 02, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Large Black rectangle on bottom half of screen
My mother-in-law had this problem on a Quasar for two years before she finally mentioned it. The rectangle is a text box for closed captioning or for a demonstation list of features, but without the text. I restored the factory presets and poof... problem solved.
Look in the manual and find how to restore the factory settings - it will probably be some weird combination of buttons that you would never guess. On her set, which has a built-in VCR, it was simultaneously pressing "play" and "FF" (on the set, not the remote) for five seconds until the set powered down. Yours will probably be something different but equally odd. That should get rid of the black rectangle. Then you go through the initial setup and you're back in business.
Jun 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Sharp Aquos LC-46D64U Large black rectangle in lower half of screen
It sounds like the closed caption text mode has been turned on. Use you CC button on the remote and make sure the closed caption mode is in the off position.
Jan 23, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Black Rectangle on lower half of TV screen.
Turn off the closed captioning feature. If a channel or program doesn't provide the captioning, all you get is the black box. Just find the menu page for that and change the setup.
Jan 10, 2008 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Black rectangle on t.v. screen
It sounds like you have the Text feature on the closed caption option turned on. your going to most likly need an original remote to turn this feature off as far as i know of. If you do not have an original toshiba remote to turn off the clkosed caption or in some sets you have to go into the menu to turn this feature off, maybe you can borrow one from a friend that has one or you can get one from http://www.remotes.com. Good liuck and let us know if you need more assistance
Oct 05, 2006 | Toshiba 32A62 32" TV
Zenith C27A24T 27" TV Logo
177 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
