Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Controls panel is lit but can't see text
The control panel is lit (back light is on) but I can't see the text of the menu.
  • jpb1 Nov 13, 2008
    Same problem, but intermittent. Sometimes just white, sometimes screen fine, other times will quickly show Firmware Rev B09. Also, the heater light will come on YELLOW. Usually this is green when spa is at the set temperature, or red when the heater is on.
  • rey1954 Mar 08, 2009
    I have same problem. It seems the digital screen has gone bad. Is there a place to get a new one or send it to get fixed?
    Problem Solver:
  • 5 Answers
This isn't published in the owners manual nor can you find it from Jandy tech support, but my RS4, All-button has a small hole on the left side of the control panel. Insert a paperclip...it's a reset button and will fix a simple problem. My display screen was scrambled and it's working fine now.
Posted on May 03, 2009
  • Avie Reader Oct 06, 2013
    My screen was blank however the Back Light was on. Follwed your instructions using the paperclip and my screen now works! Thanks, this has saved us a tremendous amount of money :-)
  • 125 Answers
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
The controls locked is displayed. what causes this and how do i get the controls unlocked.
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
The light next to the "controls locked" is lit and
If you are referring to the Control Lock on a Whirlpool Duet, Kenmore Elite, or Maytag Epic series front loader washer or dryer, this is actually a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
The following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more significant problem other than a simple operator control button issue (such as an operator console problem or main control board issue).
NOTE: Each one of these appliances come with a technical data sheet inside.
For Washers: To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
For Dryers: To access, locate and remove the three screws that hold the top panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. The technical data sheet should be located along one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot if you cannot get the control panel to unlock.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Jan 06, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
On the washing machine, on the control panel, a light is lit and states:controls locked
Try this:
Select and hold end of cycle signal for 3 seconds until the control locked status light turns off.
Sep 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
61md10 front panel controls lit uo, but the TV does not respond
With a non responsive remote that would be inpossiable you need to replace the control board inside around $100 bucks then you can have a good tv again but to get to the service menu your controll has to be working.
Aug 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
The Dryer says "Control Locked"
Try pressing an holding the "End of Cycle Signal" button on the front panel in for 3 seconds. This button is used to lock/unlock the control panel to keep small children from manipulating the controls when the dryer is not in use. A designed safety feature. If this does not work for you, please post back and let me know. I hope this helps you.
Jun 25, 2009 | Whirlpool GEW9250 Electric Dryer
Text dose not want to come off the screen
Gee thats strange they did not supply a remote and its brand new. Normally you can use the controls on the TV itself.....Are you saying it didnt have a manual? either?...then do a google search over the NET what ever your model is. Try to find some instructions? Good-luck
Jun 21, 2007 | Sanyo DP32746 32 in. LCD Television
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
525 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
