Question about Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 won't power up
We have a Canon Elura 60 and while it doesn't have any obvious signs of abuse, the blasted thing won't power up. Battery is fine, but even when I plug the camera into the wall, the indicator light does not come on. Nothing. Not a peep out of the *&^#=! thing.
Seems like just a shame to toss it and "go out and buy a new one."
thanks
  • abechdel Dec 15, 2008
    Same thing just happened to me. I was in the middle of recording and the camera just stopped. Went completely dead, battery won't charge. And a new battery won't charge.
  • Anonymous Mar 14, 2009
    i can't get it to power up via battery or via wall
The same thing happened to mine soon after I got it. Turned out the plug I was using to plug it into the wall to charge had gone bad. The replacement was over $100 so I went with a (cheaper) wall battery charger that you conect the battery to.
Posted on Mar 13, 2009
My canon elura 60 digital video camcorder doesn't zoom in and out. it seems to be stuck
Sometimes a smack around the edge of the lens will work. If it doesn't, then it might be a motor issue and will need to be taken apart.
Nov 12, 2010 | Canon Elura 60 Mini DV Digital Camcorder
My Canon Elura 60 is not working properly. The cassette will not load. I tried to change the power source to DC from battery, but it didn't solve the problem. The cassette tray loads fine without the...
Unfortunately, you will need to have your camcorder repaired. Inside of your mechanism there are several different components that can go bad and cause this problem. You might have a bad capstan motor or a bad gear. If you hear something spinning like crazy when you try and put a tape in, you have a issue with your capstan. Hope this info has helped you.
www.austintelstarservices.com
Sep 03, 2010 | Canon Elura 60 Mini DV Digital Camcorder
A flashing red symbol on the screen below the battery sign
It might be the backup battery alert. If it looks roughly like an oval with a bar through it, you need to change the button-style backup battery. The battery is a CR1616, and is located in a slide out holder that is in a slot just forward of the memory card slot.
Mar 06, 2010 | Canon Elura 60 Mini DV Digital Camcorder
Tape deck won't open
Hello.
1. Completely remove battery and then restore it and try.
2. If you here sound of engine when camera wants to open door but can`t shake door by hand.
If problem persist you need to open it inside and clean it.
Sep 07, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Zoom button of canon elura minin dv
I had a similar problem. Searching Google for a solution, I came across the old -- "if it doesn't work, smack it" trick:
Remove any tape in the camera.
Remove the battery.
With your hand holding the top of camera, hit it firmly with a book on the bottom. I used about a 200 page paperback.
I suspect it is a electro-mechanical switch that gets stuck in the "On" position, and a little jolt frees it up again.
I have done this twice in the last month, and it works great.
Aug 29, 2008 | Canon Elura 60 Mini DV Digital Camcorder
I have a canon elura 60 and im trying to download my video to my computer so i can email it to someone. how do i do this?
you need a DV firewire cable and video capture software (there are several different program on the market)
Mar 31, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
Mar 30, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 - Zoom is on maximum and won't restore. I own Canon Elura 60 since last two years and now i'm facing problems with zoom. Zoom button does go to and fro but actual zoom doesn't take...
Hi There, did you find any resolution for this problem? If you could share any info about the problem, it will be really great. Even I have the same issue with my Elura 70. Thanks.. Pradeep
Nov 08, 2006 | Canon Elura 60 Mini DV Digital Camcorder
Canon Elura 60 Mini DV Digital Camcorder Logo
341 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
