Question about Akai Ewi4000s Electronic Wind Instrument
IMac not detecting EWI4000s via midi-usb adapter
I have an Imac, and am trying to connect the Ewi4000s to it so I can update its sounds. The Ewi is set to use Channel 1, and the mac sees the USB adapter as MIDI In and Out in Uniquest.
I can't get Reason or Ableton to pick it up - I installed a new midi controller in Reason, and it saw the USB adapter; the MIDI In light flashes on the adapter, and I've plugged the In cable into the Out port and vice versa on the instrument. I'm not even sure if Uniquest can see it properly.
Does anyone know how to get this working please?
Thanks!
  • Anonymous Nov 17, 2008
    Same problem - Mac Powerbook - akai 4000s w/ an MAudio USB adapter -- the programs seem to sense a signal, but nothing more than that -- the vysex software that the ewi came won't connect either - all it sees is the adapter but doesn't seem to go a step further and see the ewi... Garage band lights up and senses something but no input is being recorded ... very frustrating...
  • Anonymous Mar 04, 2009
    same thing with me..
My Imac does not find the midi ports form my Ewi 4000S. When I try to install midi ports ( just one choice possible) it does not work. What can I do ?
Posted on Aug 29, 2010
Ewi and vocoder setup
hi, i have a YAMAHA WX5, and want to know if it's to use a Vocoder?
Mike Phillips is the same, or if it only works with the EWI 4000s?
and as a connection is made?
thank you!
Feb 04, 2013 | Akai Ewi4000s Electronic Wind Instrument
Reset. EWI4000s
Try this out
Turn off the EWI,
Press the LEVEL, FX, SETUP and TRANS buttons.
Then turn on the EWI.
This is a Factory reset.
I hope for You this is the solution.
Nov 13, 2010 | Akai Ewi4000s Electronic Wind Instrument
Just bought the EWI4000s plugged it in but no sound.
First of all I recommend reading your entire manual cover to cover. Then read it again with the EWI in hand. Go step by step following the setup procedure. You have a complex instrument so it is very easy to miss something or make a mistake. Here is a link to the best wind synth website in North America:http://www.patchmanmusic.com/ There is an 1/8" jack on the instrument for headphones. There is also a 1/4"unbalanced jack for plugging into an amp, mixer etc. Here is a link to the manual if you didn't get one:http://www.akaipro.com/ewi4000s/?tt=5 It is battery powered ( 4AA batteries ) so don't forget them. It can be powered by an optional MP9-II adapter (use the exact model ). It has a built in analog synth so if you set it up correctly you should get sound right out of the box. Hope this helps.
Oct 26, 2010 | Akai Ewi4000s Electronic Wind Instrument
EWI4000s
Try this site:http://www.patchmanmusic.com/
May 29, 2010 | Akai Ewi4000s Electronic Wind Instrument
Robert Penny robertdrum55@gmail.com Where can i buy Akai EWI4000s and EWI-USB in Australia
This is the site:http://www.elfa.com.au/products/product+details?pid=71959 Electric Factory I88 Plenty Road Preston, Victoria, Australia Tel: (613) 947-41000 www.elfa.com.au List price for the EWI usb was$999.00. If this helped please rate me.
Apr 15, 2010 | Akai Ewi4000s Electronic Wind Instrument
Internal and external sounds at the same time
Without reading the manual, the easiest solution that occurs to me is to not use a cable between the audio out on the Ewi and the amp or mixer you are using. You can also set the main volume to zero. That setting does not affect the program volume.
Jun 20, 2009 | Akai Ewi4000s Electronic Wind Instrument
EWI4000s only plays one note
Hello a_marechalro,
You can try to reset your instrument.
Turn off the EWI,
Kind regards,
Fred Roubos.
Dec 26, 2008 | Akai Ewi4000s Electronic Wind Instrument
Ewi4000s as a controller
Adjust the VB & BR knobs if theyare turned up too much, the instrument senses that as a continuous note on signal.
Dec 25, 2008 | Akai Ewi4000s Electronic Wind Instrument
Akai Ewi4000s Electronic Wind Instrument Logo
438 people viewed this question
Top Akai Music Experts
Michial Gueffroy
drivealot
Are you an Akai Music Expert? Answer questions, earn points and help others
