Question about Refrigerators
Haier refrigerator - compressor keeps running continuously
I bought a Haier refrigerator 20.7 Cu.Ft. Top Mount 2 days ago. Iplugged it in after 2 hours of delivery, it ran overnight and thecompressor has not shut off once. In between I have shut off therefrigerator for a few hours because of the constant noise. Thetemperature control is not clicking when I adjust it, temperature inthe refrigerator is 60 F and does not seem to drop. I am living in theCaribbean with average room temperature of 82. Please advise if Ishould return the refrigerator. I appreciate your help.
P.S. the frig was delivered in vertical position, tilted for about 2 minutes to carry through the door.
  • daphtodd Dec 18, 2008
    I am having the same problem. My fridge is two months old and I can't get anyone to replace it nor fix it. I also purchased a warranty
    Champion:
  • 210 Answers
Definetly return it. under warrenty.
Posted on Nov 11, 2008
I have a Haier refrigerator model #rrtg18paaw and the freezer is not working but the fan is please help?
At this point I am assuming the refrigerator portion is working. It sounds like it may be a thermostat or a low refrigerant charge. If you cannot find it with the links I have attached you should contact a servace tec but also it possibly is in warrenty so start where you purchased the unit.
Haier10 11 cu ft Top Freezer Refrigerator White
20 7 Cu Ft Frost Free Top Freezer Refrigerator ENERGY STAR HT21TS45SW
Haier Refrigerator Parts
Haier Refrigerator Model RRTG18PAAW Parts
May 30, 2016 | Haier Refrigerators
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
My 18 year old top freezer Inglis refridgerator has started to clunk. This noise began a couple of months ago. The clunk is fairly loud ( heard over the TV) and happens once every couple of hours. The...
The clunking is because the compressor has a broken mount and it clunks when it shuts off... this will eventually cause bigger problems, but probably you will need to replace the compressor to fix it...even so just check that a bolt did not come loose and that it may be a simple fix...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 06, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Refrigerator not running, was a few days ago, copressor very hot
if compressor is hot it means (a) low charge (b) locked rotor and in any case it can be fixed
May 02, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore frig freezer will go to 20 degrees and stay there
sounds like either the compressor is out or the relay that starts the compressor is out. I would try replacing the relay/overload on the compressor and hope for the best. if you have a continuity tester then check from each of the 3 posts sticking out of the side of the compressor that the relay/overload push on to fo one of the copper pipes coming off the compressor..no continuity is good if you get continuity then the compressor is shorted and ruined
Jun 13, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Problems with Maytag 21 cu.ft. Top Mount Refrigerator, MTF2172HR
not nessecarily an electrical fire, but sounds as if the compressor is struggling to start, it is indeed "tripping off" on overload. so yo may start ot see a decline in refrigeration. check your manual for "sealed system" coverage. adn check that against our date of purchase, you should have 5 yr manufactuere warr, but that all changed Jan '06 coverage was reduced to one year! yo ucan try replacing teh overlaod relay, atached ot the side of the compressor if youd like
Mar 07, 2009 | Maytag 21 cu.ft. Top Mount Refrigerator,...
Quit working -Haier Freezer
You have one of three issues here.
Either the thermostat has gone bad,
The thermal cutout has gone bad ontop of the compressor,
or the capacitor is out for the compressor.
Take an hom meter and check the thermal cutout, it should read 0 ohms or "continuity" if it doesnt the cutout is bad.
The only real way to check the cap is with a cap meter.
as for the thermostat check it with a n hom meter to make sure you have good connections internal the thermostat.
If you have any other questions just let me know!
Mar 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Top Freezer and Fridge not working
WHEN ITS NOT WORKING DO YOU HEAR A CLICKING OR BUZZING SOUND (IF SO BAD COMPRESSOR OR OVERHEATING)SEE BELOW
ALSO CHECK THE CONDENSOR FAN IN BACK IS IT RUNNING WHEN THE COMPRESSOR IS RUNNING
Feb 18, 2008 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Refrigerators Logo
303 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
