Ipod nano won't turn on - Audio Players & Recorders
  • 35 Answers
Hold down the center button and the menu button at the same time until you see signs of life!
Posted on Nov 11, 2008
3 Suggested Answers
smilemaker
  • 790 Answers
SOURCE: Hi Just Won A iPod nano. need help starting.
Hello!!
Download manual from here
http://manuals.info.apple.com/en/iPodshuffleUserGuide.pdf
Posted on Jun 23, 2009
  • 846 Answers
SOURCE: i charged my 4gb nano 3rd gen ipod, but it won,t
if the hard reset or restore doesn't work, you may need a new logic board. There is a service that offers repairs for the nano. iPod nano 4g Repair
Posted on Nov 18, 2009
Mp3 Ver: ld 3088 - std 1.1 does not recognized! help!
There are several reasons why your iPod Nano may not turn on or awake out of its "Sleep Mode." This can be extremely irritating if you wish to use your iPod Nano, but the device is constantly malfunctioning. You may not need to take your iPod Nano in to be repaired if the player doesn't turn on as normal. There are a variety of different fixes that you can attempt as a way to get the Nano to turn on.
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
Feb 03, 2013 | Apple iPod nano 3rd Generation
Ipod wont turn on
Flip the iPod Nano's "Hold" switch to "OFF." The iPod Nano cannot be turn on if the switch is set to "ON." Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF." Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds. The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again. Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes. Then, try to turn the Nano on. Update the iPod Nano's software. Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes. Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes. Follow the instructions that appear inside iTunes in order to install the updates on the Nano. Hope this helps.
Jan 22, 2013 | Apple iPod nano
What is wrong with my ipod ao 5th generation
hope this helps
Sep 23, 2012 | Audio Players & Recorders
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
I charged my 4gb nano 3rd gen ipod, but it won,t
slide the hold switch on and off a couple of times...then press and hold menu and center buttons till an apple logo comes on screen...connect to system and restore with itunes.
Sep 10, 2009 | Apple iPod nano
What should i do to turn hold off after opening up ipod nano 1gen
HI,
The "hold" switch is located at the top of the iPod nano.
TO TURN THE HOLD ON:
Slide the hold switch to the on position when you put the iPod away. This won’t accidentally wake from sleep when a button is pushed and drain its power.
TO TURN THE HOLD Off:
To start using your iPod again, just slide the hold switch into the other position and click a button to start it up again.
This will fix the issue,
Thank you,
Jul 16, 2009 | Audio Players & Recorders
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
Dec 22, 2008 | Apple iPod nano
Ipod nano 2nd generation won't fast forward
Turn repeat off in the menu.
Setting iPod nano to Repeat Songs
You can set iPod nano to repeat a song over and over, or to repeat a sequence of
songs. iPod nano repeats songs within the list you choose to play.
To set iPod nano to repeat songs:
m Choose Settings from the iPod nano main menu.
â To repeat all songs in the list, set Repeat to All.
â To repeat one song over and over, set Repeat to One.
To turn repat off, go to Repeat off.
May 21, 2008 | Apple iPod nano 2nd Generation MP3 Player
Ipod
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
174 people viewed this question
 Grubhead
Grubhead
