Question about Sun Mate Portable Cooler and Warmer
Need new A/C adaptor
A/C adaptor stopped working after a short brownout when the power came bacl on (I suppose it was a power surge). I've tried to find a replacement and either I don't know the correct verbiage to do a google search (I've used Input 100-240 VAC 50-60 Hz 1.0 A Output +12VDC 4A) or they don't have this avaiable. Can anyone help? I need my Diet Mt. Dew at my desk again!!!! KC
  • 237 Answers
Is this the type you need? http://www.amazon.com/110vac-12vdc-Adapter-5-Amp/dp/B000BSLU78/ref=pd_sim_dbs_k_1/102-1988551-4156140
Posted on Nov 11, 2006
Tanning bed will not power on there is power to it but through numbers do not light up. We were hit with a power surge and it did not come on. I have a surge protector on it and it is still working
I've seen this happen with an AMP/Receiver before.
Short answer was to unplug the unit and reset the power bar/surge suppressor.
Something about the surge/brownout tripped either the power bar or the AMP.
It could also be possible that a fuse inside has been blown.
Dec 23, 2016 | Health & Beauty
Why does router start then stop
They can do that if they overheat. Is the router hot? If there was a power spike or brownout, the router could have been damaged. Do you have a surge protection system?
Aug 29, 2014 | Computers & Internet
KERNAL_SECURITY_CHECK_FAILURE
Possibly a bad battery or power adaptor. Try running with the battery out of the laptop. If that doesnt work try a new power adaptor. If after all that, it still doesnt work, it may be your mobo(motherboard). A power surge can easily destroy a mobo.
Feb 06, 2014 | ASUS Computers & Internet
EEE PC 1005P won't charge, can it be a motherboard problem?
honestly you've done everything correctly that i could think of. one last thing you could try to root out a problem with the os. is boot the computer from hirens boot disk and load the portable Windows. see if the battery is detected in hirens. then youll know if its a Windows problem or not.
personally i feel the board is the issue but it doesn't hurt to check the complete os.
Feb 26, 2017 | Computers & Internet
I've got a Dell Studio 1735 that started to tell me the battery was on the way out after 18 months (maybe a bit more). One day the battery stopped charging and when it ran down completely it...
There is a short circuit on your motherboard. This is why the power adapter switched off (thermal cutout) and resets after you remove the adapter from the wall power outlet.
You need a new motherboard.
Aug 19, 2011 | Dell STUDIO 1735 Motherboard - H274K
I have no power to my Hitachi TV. It is plugged
try turning off main switch and unplug set then replug in wait 30 sec turn on main power and repeat then try if it works great if not power supply bad. i also suggest a ups universal power supply newer tvs sensitive to surges and brownouts also never turn tv off n on in short period of time will cause surge that trips protection circuit
Dec 29, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Apple Cinema Display 23" LED short-long-short flash prob.
Hello, I had the "short long short" blinking led problem with my 23" ACD after a power outage which left my screen blank and my cheek wet with a tear for my baby. I read somewhere that a guy was getting a 1 volt reading on the middle pin of his damaged 90 watt power block. I figured maybe the display might work if I could somehow block the middle pin. So I cut a small strip of paper wide enough to block just the middle pin and long enough to cover both sides, folded it to look like a "W" from the side. I then carefully pressed it into the brick receptacle with a toothpick leaving just a little slack so it would not tear when I pushed in the small white plug. It was a bit of a tight fit but guess what. IT WORKED! I am now enjoying my beloved monitor anew and saved $$$ on replacement brick or repair. If you want to try it and you feel you’ve nothing to lose, make sure you cover just the middle pin (both sides) and you may have to try a couple of times. It worked for me. I hope you have good luck too. Regards, Moozler
edit December 2016. Still working after 7 years.
***CAVEAT AND WARNING***
Use this fix at your own risk.
A faulty voltage regulator is probably the cause of failure. Voltage regulators can start a fire if too much voltage is applied.
Bud Martin's post below describes the electronic component failure that causes this problem. Thank you Bud.
Jul 19, 2009 | Apple Cinema Display 23" HD Monitor
Problem with power cord/AC adaptor...maybe?
I would just go buy another battery charger pack. They are like 75 dollars to buy. Sounds like yours might have a short in it!
Mar 26, 2009 | HP Compaq nx6110 Notebook
Lexmark z23 froze after power hit
the adapter of the printer is got short and its towards it end.get it repaired to make the use of same adapter if you will keep the printer ON this adaptor will go completely dead due to getting heated.and will become total scrap and you will have to buy a new replacement adaptor worth $20 to make your printer work again.this is a very common problem in this printer of adapter getting short due to power surge, thanks,
Nov 20, 2008 | Lexmark Color JetPrinter Z23 InkJet
Cyberpower 825avr
It would appear that you need to replace the battery on this unit.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (HR9-12 battery).
We have a 3 year warranty on all our battery back up units. If you have any questions, you could contact us here at CyberPower Systems Technical Support at 877-297-6937, M-F 8-5 Central, or email us at tech@cyberpowersystems.com.
Jul 05, 2008 | CyberPower 825AVR (cps825avr-sc) UPS...
Sun Mate Portable Cooler and Warmer Logo
66 people viewed this question
Top Sun Mate Refrigerators Experts
Marvin
Marvin
Gil Shultz
Are you a Sun Mate Refrigerator Expert? Answer questions, earn points and help others
