Question about Garmin GPS 72 GPS Receiver
Garmin gps 72 not aquiring satelites
My gps 72 has stopped aquiring satelites. Garmin suggeted a master reset , which I did but it has made no difference
Any Ideas?
JD
  • 2 more comments
  • GPS72 Dec 11, 2008
    My GPS72 has the same problem. I contacted Garmin and they told me the same thing. I have done a master reset but this has not cured the problem.
  • shivaraj2008 Dec 12, 2008
    my GPS 72 not aquiring satellites, and who to do the master reset plz help me...
  • Anonymous Jan 31, 2009
    how make a reset for a gps garmin 72
  • Anonymous Mar 19, 2009
Press POWER ON and PAGE buttons at startup and leave for 20 minutes to initiate
Posted on Mar 24, 2009
Garmin gps 72. how to do a master reset
Press POWER ON and PAGE buttons at startup and leave for 20 minutes to initiat.
gps holder
Sep 18, 2012 | Garmin GPS 72 GPS Receiver
Hello i have a nuvi 660 and it does not receive any satelite it says aquiring satelites and never gets any
To perform a Master Reset on the nuvi 200, 205, 465, 500, 600, 700, 705, 1100, 1200, 1300, 1400 or 1600 series device:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings. If you would like to back up your favorites you can find instructions to do so here.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers ON
    • You will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Follow the on screen prompts then place your device in an area with a clear view of the sky until it acquires satellites.
Oct 23, 2010 | Garmin Nuvi 660 GPS Receiver
Keeps saying locating satelites or aquiring
Usually a reset will fix this. Make sure it has a clear view of the sky and ful charge or on the charger. reset and let it download and install new catalogs. Then it should be able to restart normally and know where it is.
Mar 23, 2010 | Garmin StreetPilot C330 GPS Receiver
My Garmin Nuvi 350 does not aquire sattalites?
Make sure it is in its mount. The antenna is in the mount and needs to be connected tight also make sure You have a view of the sky and not parked in a garage that blocks the signal
Oct 28, 2009 | Garmin Nuvi 350 Car GPS Receiver
Unable to Track Satellites
My garmin will idle after turning it on "aquiring satelites", after awhile it will give me the white screen "trouble tracking satelites, are you indoors now?" answer "no"when the garmin asks you if you are in a particular state answer "no". It works for me everytime, don't know why, just that it works to lie sometimes.
Apr 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin GPS problem
I have a 276C that has the same problem. Garmin has a unit with this problem and is working on a solution. The problem is that the real time clock loses time when the unit is turned off and disconnected from a power source. As a result when you turn on the unit it thinks the satelites are in a different orbit than where they actually are. The unit will continue trying to aquire forever and not find the satelites. You have to select "New Location" from the menu and select "Autolocate" and the unit will start to look for any satelites in view. The unit should get a fix within 15 minutes. This is a very frustrating problem having to reset it every day. There is a new version of firmware (5.3). I don't know if the problem has been fixed with this release.
Jun 15, 2008 | Garmin GPSMAP 276C GPS Receiver
Cant find satellites
same problem the acquiring satellites appears with a flashing '?' some where in central london 'horseguard', ......the unit switches on and off i have reset it used hard and soft reset methods.....updated the unit....same problem....
garmin streetpilot c510 delux model
Apr 07, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Garmin nuvi 310 satellite aquire problem
I have a Garmin Nuvi 350. I solved the problem by purchasing a Glisson GPS antenna that plugs into the external GPS connector on the Garmin antenna.
Apr 04, 2008 | Garmin GPS
Garmin 360
have you ever updated the firmware (webupdater @ www.garmin.com)?
Dec 12, 2007 | Garmin nuvi 350 GPS Receiver
Garmin GPS 72 GPS Receiver Logo
681 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
