Question about Mitsubishi WS-55613 55" Rear Projection HDTV
Ws55807 I turn tv on it starts slow with great picture then after a while it fads out,then it may come back again .If i turn it off for a minute it may come back on great and some times not .But when it comes on it stayes on all day.This has been going on for a year.This started after a repair job ,they replaced a gun I sent it back at that time and it did not do it ,but it does it every day i need help thanks bill
  • mrbill9608 May 31, 2009
    this problem gets worse in hi humidity I removed front cover on the right side on bottem there is a cercuit board with a aluminum tower 3 inches tall 1 inch square ,if the tv is goasty i take a hair dryer to this object for a few seconds a tv get ok some times it goes out i put the hair dryer on again tv gets ok is there a name for this part and is the problem thanks bill.
  • 822 Answers
Check CRT socket. resolder CRT circuit board and main board. its a loose contact.
Posted on May 31, 2009
    Sergeant:
  • 296 Answers
Hi
your convergence circuit has started giving trouble .... normal thing after a few years running for projection televisions ...... could be that the convergence IC's are getting too hot (two big IC's on a heast sink bearing an STK number on it) or that you have some loose soldering that needs to be resoldered on them.... worth the check
or have your power supply circuit board checked, if nothing seems wrong trouble leads to your horizontal deflection circuit board.
regards
Posted on May 28, 2009
Tv works great and awesome picture for about 5 minutes. screen blacks out but still has sound, if i turn it off and back on picture comes back for another 2-5 minutes.
Your power supply is starting to fail. It produces several voltages for the different boards inside. There is a board called a T Con board that controls the picture. It would be suspect too. You can get parts for your TV from here.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Nov 23, 2015 | Televison & Video
Turn on TV and picture and sound are great for about 60 seconds. Then the picture disappears but sound remains.
I would start with checking the power supply 12vdc output, make sure it is stable with no ripple. If the power supply checks out fine, I would then suspect the main board.
Sep 20, 2012 | Vizio VT470M 47-inch 1080p 120Hz 5ms LCD...
Power light comes on for 2 seconds and then off.
Need to have the power supply rebuilt, expect to pay around $350 Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Mitsubishi WS-55807 TV
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Fads to green with spiraling lines
you may have a short in the picture tube. but from your description it sounds like the positor has failed. really hard from your description but if the positor has failed its very cheap to replace..farr64
Apr 27, 2009 | Televison & Video
Picture fads to Blue after a 30 minutes the picture comes back with a blue tint.
yeah you need a tech to adjust the bias of the picture tube if you are lucky that fix it other wise the blue picture tube is bad
Apr 29, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Mitsubishi ws55807
does the menu show up?
Oct 31, 2007 | Mitsubishi WS-55807 TV
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
