Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Wirless connection my laptop is able to find network free connections but im not be able to connect it.
  • georgesath Nov 10, 2008
    hi! no, it's not my own network...when i search for a wireless network i found unsecured network but i can not connect...the message appears "no longer in range"...i'm wondering why my officemate had no problem to connect it... i was advise by a friend that maybe the problem is my laptop toshiba M105-s3011 signal is very weak...is there any software or hardware to fix this problem.
  • Jannette Amandy May 11, 2010
    Is the network you're connecting to, your own "wireless network"?
    Scholar:
  • 132 Answers
You may update the driver of the wireless adapter installed to your Toshiba laptop.
Posted on Nov 10, 2008
Hello, im trying to install my wirless printer to my wireless computer and im having some difficulties. for example its asking me to check my wireless LAN access point.. I dont know waht that is? im...
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device.
You need a wireless card that connects to the wireless router or wireless access point.
Otherwise you can connect to your printer using a printer cable.
May 16, 2011 | Canon MP560 All-In-One InkJet Printer
I can not connect to my wirless local net work on my acer laptop what can I do to fix the problem? ( I was have a problem with avg free and it wasnt allowing anything to work on IE8 so i unistalled avg...
This should be a simple fix, do the following below.
1) Go to start, run, cmd, OK
2) After Cmd opens type this:-
netsh winsock reset catalog
--press enter
3) and again after pressing enter
netsh intip reset reset.log
4) Reboot
You should now be able to access the internet and your router etc.
After doing this go through and set up a new network, WiFi connection, using the icon, in the system toolbar, bottom right, click on the ICON, Right click, and select "Connect to wireless network" Select your network, if asked supply the WEP/WAP Key, password, and login, now you should be able to access the internet, through the router.
Also on laptop, in fact ALL "Clients" ie: Anyone who connects to the router. MUST have a Computer Name, a Windows login password, have sharing enabled, They also must have DHCP & Zero Configuration disabled in services. go, START>>RUN>>services.msc (enter), when the services window comes up, scroll down to DHCP, and turn OFF, set to Disabled, on start up, then, scroll down to Zero Configuration,and stop that and disable from starting too. Now reboot.
Apr 15, 2010 | Acer Aspire 3680 Laptop
I have a laptop computer, and a wirless no internet
your internet gateway (the modem)if you have att you must turn on the the wireless inside your 17XXhg gateway modem if you don't then you have another system I gave you a example to clear your question if you need more help please repost with more information
Jan 14, 2010 | Computers & Internet
My new wirless acer aspireone d250 will not connect to my network, it keeps tell me its unable to connect to preferred wireless network
Wireless Network? With password for login OR for free.....? Make sure this....
If your laptop have wireless internal and turn ON. See your indicator WiFi. And your laptop may be detect some hotspots in your area. If ready to know that hotspot, that's mean your WiFi in laptop is WORKING for that purpose. And you can ask to network administrator for your purpose and log into internet (with WPA key or for free...)
Sep 22, 2009 | Acer Aspire One PC Notebook
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
Need to add a wirless code to laptop so it will geta wirless signal
For wireless connection you need a wireless adaptor in your laptop. Most of the laptop comes with wireless adaptor. If you have one then go to control panel--> network connection--> right click on wireless connection and view available networks in your area.
Please note : If you see a lock sign in front of a network it means that network is secured and you cant access it without password.
Please mail me if you need any other help or if something is not clear in my answer
Please rate my answer and Good luck !!
Sep 28, 2008 | Acer Computers & Internet
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
DV4000 cant connect to wireless network
HP bought several motherboards from the same company in China. These boards work for about 15 months then they can't find the wireless card. This is caused by a defect in the North Bridge chip overheating over time. This chip is not replaceable at the local level. You can send it back to HP for a replacement and sometimes they will charge you $300 - $500, or you can just replace the motherboard yourself. Check with them first since there is an ungoing lawsuit regarding these boards. Either way the only fix is to replace the motherboard. This is also a problem for the dv6000 and the dv9000 models. HP knows that 30% of these will fail.
Regards,
Mike
May 22, 2008 | HP Pavilion dv4000 Notebook
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
53 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
