Turn my pc on and it starts - i can hear fans etc working but the problem is my sreen doesnt come on, it says no signal. this is a problem with the pc not the sreen since i have tryed my downstairs pc sreen and it said the same im uesing a m1100 acer do u anything tip on how to slove this problem would be great. (my mate said i need a new prosseser since mine is not working fully if this is true where can i buy just the prosser)
  • 47 Answers
Well, it could be your processor , but my best bet is your video card. I had an acer and my video card was garbage. If i were you id probably bring it to a computer repair shop. If it is your video card ,it will cost you around $75- $600, all depends what your looking for. If its a processor problem then prices can range from $75- $1500.Again same story, it depends what your looking for. If your a gamer and don't want to spend to much money your looking at around $250- $300, same story with the processor ,if your a gamer. If your not a gamer then youll probally find what your looking for at around $150-$170 (video card) and $70-$150 for the processor.
Posted on Nov 09, 2008
How can i see fi is working
Turn itcon and pay attention to what noises you hear when it starts up. Fans, hard drives, monitors etc will givecimoortant diagnostics.
Sep 22, 2014 | Intel CTL E09XPH 9” 2goPC Laptop ... PC...
Turn ON not working properly
Sometimes the PSU doesn't wake up properly. I would suggest testing the PSU and looking for blown capacitors on the motherboard. They should be dished or flat and clean. If they are domed or have a gritty substance on them they need replacing or the motherboard will need to be replaced. A PSU tester will only cost about 5GBP or equivalent.
May 11, 2013 | Computers & Internet
My compaq presario sr1103wm doesn't boot up it
First of all.. try connecting all your peripheals to your PC.(monitor, mouse,keyboard,mic,speakers,etc)
Then u should open your pc and remove BIOS battery and leave it out for few minutes and put it back in...
if that doesnt work u should remove all your RAMS (memory chips next to processor) carefully and start your PC without them, u should hear some beeps, that okay, just a warning, after that put them back in and start again.
if that doesnt work try changing your hard drive with another one, or just take yours and test it somewhere else.
the last u should check your power supply, i see it starts up and then shuts down.. if your power supply is dead u couldnt even start PC, maybe there is a problem with your power outlet, try changing cables and outlets, if still doesnt work test your power supply on other PC.
if none of this works then u probably have issues with motherboard or processor.. then you should take it to service
:D
Feb 16, 2013 | Computers & Internet
Hp pavilion slimline s3020n PC the computer says no analog signal the problem is all the time cant run the computer at all.i have not tried to fix the problem myself
Does the computer turn ON? (do you hear beeps?, do you see lights on the computer NOT THE MONITOR?, do you hear the fans?, etc...) it could be the monitor, try an other one, it could be the video card, swap it with a known good one ,it could be the VGA cable change it, etc... if the computer is all dead try an other electric outlet.
Jan 13, 2011 | HP Pavilion Slimline S3020N PC Desktop
When i turn the power on, 3 beeps play, the fan runs and the power light comes on, but nothing else
Hearing ONE beep is normal, and a signal that the computer hardware is OK.
Hearing THREE beeps is a signal that something is wrong:
* burnt-out CPU,
* one of the fans is not spinning (clogged?) or spinning too slowly (about to seize-up),
* one of the RAM chips is defective
* the video-card is not working
If there is more than one RAM stick, remove all but one stick, and start it up, to see if it starts.
Check that the fans are spinning freely.
Dec 14, 2010 | Gateway GM5260 PC Desktop
MY LAPTOP WILL NOT TURN ON
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
If this doesnt work can you hear any fans or hard disk activity when you press the power button?
Jan 20, 2009 | Toshiba Satellite M35X-S349 Notebook
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
When I turn it on, I can hear the fan working, but the screen is
Hi, is possible that on having hibernated your equipment has blocked himself, tries removing the external battery and it connecting only to the AC Adapter, try turn on, as soon as the equipment completes the load of the operating system, turn off and place again the external battery, must work
Jan 08, 2009 | Toshiba Satellite M35X-S349 Notebook
Compaq presario # SR1810NX model
Please try to uninstall the memory and fixed back then start the computer.
i same problems; Back up your important files and then provide windowsxp bootable disk and boot to cd/DVD rom and install the new windows.
Jan 04, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Computers & Internet Logo
David Payne
David Payne
