Question about Hitachi 46UX24B/25K 46" Rear Projection Television
Power goes off intermittently while viewing
When power suddenly goes off,I use remote to power on producing this result: I hear the familiar "shutting OFF" sound ,I press power button on the remote a second time and the power comes on as usual. I am OK for sometimes an hour,sometimes only 5 minutes. The overall picture is always great. This set is 10 years old. I am 70 and can't afford another new TV at today's prices. Would it do any good to unplug it,take the back off and vacuum out the dust? This is NOT a worn power cord problem ; it has not been moved for 10 years.
  • 1 more comment
  • armyretired Mar 10, 2008
    When cold, the TV comes on normally. After it warms up it shuts itself off. It first did this about 1 week ago, and wouldn't come back on at all. I unplugged her and she came back on and after about 3 minutes the screend blinked once or twice, but stayed on. This weekend she started shutting of again with a vengence. Every 2 or 3 minutes and unplugging doesn't make a difference. On and then off. I read the other post suggesting a voltage regulator, but I am reluctant to start buying and hanging parts without some other confirmation. Is that a common fault / repair? Are the others AS common or is the VR in a 12 year old set a likely candidate.
  • Anonymous Apr 08, 2009
    Intermittently turns itself off. Can be turned back on after a few seconds, but may shut off again at any time.
  • Anonymous Mar 27, 2014
    tv stays off after power outage sometimes for days
REPLACE VOLTAGE REG. STRM6511.
Posted on Mar 21, 2007
My old remote for my Toshiba tv broke. I now have omega 23113 remote control and need to connect to my tv
Pushing TV, then POWER might produce results but if the Omega remote control is not compatible with your Toshiba TV you will continue to get no results.
Aug 11, 2018 | Toshiba Televison & Video
Why won't my mitsubishi lt-3040 flat screen tv won't turn on?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Jul 16, 2014 | Mitsubishi Televison & Video
Kenwood VR 605 power light flashes
CHECK FOR CLEARED COOLING VENTS & FOR PROPERLY WORKING COOLING FANS. THIS WILL CAUSE SHUTDOWN OF THE UNIT. IF ITS ALL CLEAR, YOU PROBABLY HAVE A POWER SUPPLY ISSUE.
Dec 10, 2013 | Kenwood VR-605 Receiver
I was watching TV and suddenly the screen went black. No picture, no sound. On/off timer LED on TV started blinking. I could not turn it on (or off) with remote or ON switch on TV. I found that if I...
The television is shutting itself off to protect itself. The blinking light is a code pattern. The specific code determines whether or not you need an LCD Controller Unit, Main Board, power supply or something else. You would need the service manual. There are parts distributors you can get it from and the parts as well. If soldering and tv repair is not something you are entirely familiar you may want to seek a tv repair person. The manufacturer's support may walk you through the service menus to complete a factory reset depending upon the symptoms.
Sep 28, 2010 | Televison & Video
My kf-e50a10 lcd projection tv suddenly just shut off and when i
Check your fans. You have a stuck fan. You may want to call a service center as it is a pain to get to one or two of the fans. Theres 3 or 4 of them.
Dec 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
1997 Grand Cherokee 4.0, ignition shuts down sometimes backfires and keeps going, or dies completely and hopefully starts up.already replaced coil and crank sensor.
The likely answer to your problem is that you have an intermittent disconnect in the ignition system. If power supply to the ignition system drops out, some fuel still goes through and when power returns it ignites in the exhaust resulting in a backfire. I would look for a bad ignition switch, or other loose connection that could me making/breaking contact intermittently.
Jun 23, 2009 | 1996 Jeep Grand Cherokee
Gateway fpd 1960 goes black intermittently
Your inverter is dying. It produces ~2k volts for the ccfl (cold cathode fluorescent lights) that surround your display. At a few milliamps. Probably bad or leaking capacitors on the inverter or power supply board. So it is either using too much power (bad ccfl) or a weakening power supply (higher likely).
It could be cold solder connections becoming intermittent. Remove the base, remove the screws on the backside, and split the case CAREFULLY. Inspect the power supply and inverter for obvious failure or leaking capacitors. Replace same... If your lucky, it will work.
tom
Jan 04, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
'standby' mode and akb error number
AKB 66 in self diagnostic test means...TV goes to standby (shut-off) for AKB problem 66 times. AKB is White-Balance signal and it is not proper or maintained in your TV. So error signal produced and TV goes to shut-down state.
Regardnig Standby button, its available on remote only. If you push TV Power switch, TV will switch ON, push it again to OFF TV. Power Button on remote set TV in standby status and you dont need to push power button of TV itself.
Aug 14, 2008 | Sony KP-53HS10 TV
TV SHUTDOWN
hi there, there is a power supply section problem, do some test, automatic shutdown means a power supply section problem. ty
Jan 10, 2008 | Sanyo HT32744 32" TV
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Televison & Video Logo
157 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
