Getting audio on sony home theatre from tv, and bdp
I have all sony equipment, and i cannot get sound from the home theatre when using the bdp or the tv.
I changed a setting under sound from variable to fixed.
Posted on Nov 10, 2008
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
I can not find the audio out jack on my 47 inch avol tv. its full hd and lcd . i want to be able to hear my tv through my sony surround sound home theatre system...help
You might name the model of the TV.
If the TV is a monitor it doesn't have any audio capabilites. What you should do, and owners of monitors must do, is get the best digital or analog audio from the same source the TV would get it - cable/sat/dvd/bd/game.
There is nothing to be gained by washing hi-fi multi-channel audio through a TV's sub-par audio electronics and turning it into grainy analog audio for consumption by higher-fi audio-specific equipment..
May 30, 2010 | Audio Players & Recorders
Installing sony dvd home theatre dvd recorder to digital tv
you may have to press the audio button or set the audio stream on the dvd's (disc) menu, as some films use the 2 channel audio as default
Jan 02, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
How can i connect the system to a new sony bluray
use your tv as a common connection in your theatre system. Connect your hdmi blue ray player to the tv,connect the audio output of your tv (rca style cables -red&white) or if your tv and audio system has optical you can use that also.
Dec 23, 2009 | Panasonic SC-HT500 System
Panasonic 50? Plazma TV TH 50PZ 800A + Sony Model DAV ? SB 500W
that is possible
the home theater has so many in puts on your dvd and out puts.
there is a way
1 you can buy a vedio/audio converted to rf signals, this will mean both signals entering tv using rf.
2 get your vedio out from dvd and audio out, feed that to a converter, vedio in and audio in okey
Jan 07, 2009 | Sony DAV-SB500W System
T v and home theatre sony bravia
As most home theatre systems offer no analogue audio input and only use the audio coming from the dvd being played the short answer is no.
If your home theatre system has a digital input and the tv has the corresponding output then yes you could me able to connect the two. Otherwise you could try to get hold of a analogue to digital converter and convert the tv's audio out to digital.
Jan 11, 2008 | Audio Players & Recorders
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
Top Televison & Video Experts
