Question about Casio fx-300ES Calculator
Casio fx-83 when i try this for example: 0.05/12, the answer comes up as a fraction or 4.16666667*10^-3. i want the calculator to display the result of this type of calculation as a simple decimal answer such as 0.00416 because i have to do these calculations in my university exam this week
  • rakhee_akz Nov 10, 2008
    that does not work. when i press mode this comes up:
    1: Comp 2: Stat
    3: Table
Press mode untill u see FIX and then the numba of decimal places u want
Posted on Nov 09, 2008
My Casio fxfx-85ES does this, You need to press the S<>D button above the Del button. it is a bit annoying becasue you have to do it every time your turn it of.
Posted on May 31, 2009
Every answer to even addition problems are displayed as fractions. We have tried everything.
To convert a single result from symbolic (fraction) to decimal, press the S--D button. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Sep 07, 2011 | Casio FX-115ES Scientific Calculator
My new casio fx-300ES calculator outputs answers as a fraction... how can i change the output to a decimal point?
To change a displayed result into a fraction, press the [S=D] key.
To force a result to be displayed as a decimal number before it is displayed, press [SHIF][=] instead of [=].
Aug 15, 2011 | Casio fx-300ES Calculator
While using Casio fx-300ES , I am unable to get answers in decimals. For eg. 3/10...should give 0.3, but the answer is again displayed as 3/10. any way to solve this issue?
The calculator has two Input/Output modes: MathIO and LineIO.
LineIO
LineIO is the old way of entering numbers in calculators and results are always displayed as decimal numbers. Some calculators have a fraction feature and would convert a fraction to a decimal number and back.
MathIO
In MathIO you enter expressions as you would by hand or as you see them written in textbooks.
In this mode, results are by default displayed as fraction or fractions/ radicals.
Conversion
To convert the fraction/radical to decimals you just press the [SD] key. If you press again you cycle through all the available display formats.
So you can (if you want) use the MathIO to manipulate expressions and convert only the last result to decimal. By the way, fractions and radicals are generally more accurate than their decimal representations.
SetUP
If however seeing fractions and radicals is too painful, just set the LineIO as your default mode. To do so press [SHIFT][MODE] to open (SETUP), then select [2:LineIO]
Feb 17, 2011 | Casio fx-300ES Calculator
My Casio fx-115 ES Natural Display is solving 21.9 in a fraction when I put the calculator in scientific mode.... Why?
If the calculator is in the MthIO mode it will always attempt to display the result as a fraction. To convert a single result to decimal, press SD. To have the result always come out in decimal (according to the selected display mode), press SHIFT MODE 2 to select the LineIO mode.
Oct 07, 2010 | Casio FX-115ES Scientific Calculator
Why does the answers goes to fractions
In MathIO mode the calculator tries to display answers as fractions whenever possible. You can convert a single result to decimal by pressing the SD key just above DEL. To have all results come out in decimal format, press SHIFT MODE 2 to select LineIO mode.
Sep 12, 2010 | Casio FX-115ES Scientific Calculator
I cannot find how to change my answer display to a decimal instead of a fraction on a Casio FX-115ES. I am working with financial formulas and need decimals! Anyone???
If the result is already calculated and displayed, press the [S<=>D] key It will convert a fraction or radical to decimal. This is always possible. If the result is decimal it may be converted to a fraction or a radical (Not always possible).
If the expression to be evaluated is still in the command line and you have not pressed the [=] key, you can force the result to be displayed in decimal format by pressing [SHIFT][=] instead of just [=].
More permanently. If you do n o care for fractions and radicals, set the Input/Outpout mode to LineIO. To do do press [SHIFT][MODE] to access the (SETUP) screen and select [2:LineIO]
May 20, 2010 | Casio FX-115ES Scientific Calculator
Casio fx-300ES Default answer readout?
Generally, MathIO gives results in fractions or radicals. But sometimes it does not. I tried multiplying or dividing fractions or radicals by integer numbers, and once in while I got a decimal result and was unable to cast it into a fraction or a radical. I was not able to find the pattern.
In lineIO you only get decimal results.
What can one tell you that you cannot determine for yourself? If you appreciate the functionalities of the MathIO, it seems like an insignificant price to pay to press ONE button to switch between displays. It needs to be done ONLY once, for the last result one wants to record.
Your calculator, Your rules. But sometimes one cannot eat the cake and have it too.
Oct 20, 2009 | Casio fx-300ES Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
Casio fx-300ES Calculator Logo
353 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
