Question about Philips SA5125/37 MP3 Player
Wont turn on
My mp3 will not turn on, i did try the device manager to repair it. I followed the instructions on holing the back button on my mp3, then plugging it up to my usb. Afterwards I open up the philips device manager. Before it repaired it, but know it wont because my computer says that it dosnt reconize my mp3. Please help me on how to fix my mp3
  • 8,596 Answers
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Dec 12, 2008
My phillips mp3 will freeze on 99% updated everytime i unplug it from the comp what do i do?? i have tried reseting it and then it gets frozen on the "vibe" screen...
Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you format your player or repair it using Philips songbird or device manager. If your model number starts with SA1..... your player supports device manager. If it starts with SA2.... then it uses Philips Songbird. You can install them from the CD that came with your player or download it from Philips support site.
Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair using Songbird:
Launch Songbird and then connect your player to your computer. Select "Repair" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
Repair using Device manager:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Hope this works.
Apr 13, 2011 | Philips GOGEAR SA6045 MP3 Player
Will not power on will not recharge
If that doesn't work, I'd suggest that you format your player or repair it using Philips songbird or device manager depending on which software is used on your MP3 player. If your model number starts with SA1..... your player supports device manager. If it starts with SA2.... then it uses Philips Songbird. You can install them from the CD that came with your player or download it from Philips support site.
Format:
Hope it helps.
Feb 27, 2011 | Philips GoGear ViBE Digital Media Player
My compter does not reconize my mp3
It seems your player hang up. Firstly, I'd suggest that you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds. Now turn it on.
If that doesn't work, I'd suggest that you restore factory settings or repair it Philips Device manager. You can install them from the CD that came with your player or download it from Philips support site.
Hope this works.
Feb 07, 2011 | Philips GoGear Flash MP3 Player
It wont format, it wont let me delete or even add songs? what do i do?
There are two to reformat your device. Just follow these instructions
From menu of your device:
1. Turn on your Sansa C240
2. From the main options menu, select " Settings "
3. Select " Format " and " Yes "
Formatting Manually:
1. Turn off Sansa C240
2. Slide the " Hold " switch on the bottom of the device to the " On " position
3. Press and hold the " Play " button. Press and release the " Power " button.
4. Hold the " Play " button until the LED screen displays the message " About to format device."
5. Release the " Play " button and press the " Next " button once.
Try these steps and let me know if you manage to reformat your device.
I could instruct you on how to reformat this device on your pc just post back.
If these solutions helped you.. please rate this answer and leave some testimonial too.
Thank you
Nov 17, 2010 | SanDisk Sansa c240 MP3 Player
My mp3 wont be recognized by my computer and it wont turn on nether
press and hole volume + button while connecting to pc...this should put it into recover mode....then use Philips device manager to repair it
Aug 13, 2009 | Philips GoGear SA3125/37 MP3 Player
Phillips SA3025/37
Triple Reset for GoGear:
-Tha Mp3 Doctor
Jun 13, 2008 | Philips SA3125\02 MP3 Player
Wont start
Could be corrupt firmware.
Install and run Philips Device Manager from the product CD.
Select the Repair / Restore option.
Press and hold [VOL+] on the player whilst connecting to the PC, and follow the on-screen prompts.
Apr 01, 2008 | Philips SA5125/37 MP3 Player
Memory repair
Did you get a pop-up that said the repair was successfully completed? If not, then try the following repair instructions:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
After this, you may be able to go back into Device Manager and click the Update tab to get the firmware upgrade which solves the memory corruption problem.
-Tha Mp3 Doctor
Feb 02, 2008 | Philips SA5125/37 MP3 Player
Can not download music
Try repairing the device before performing the firmware upgrade:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Jan 01, 2008 | Philips GoGear HDD075/17 MP3 Player
Philips SA5125/37 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
