My Megaflow Immersion Heater D70 suddenly stopped heating the water. I only use it for hot water, not heating. The fuse was fine but I switched on and off just in case with no result. It is getting on a bit at 6 years but wonder if there is anything I can do before I call in the plumbers. Also, if it is worthwhile getting parts for this tank or replace it.Live in hard water area so maybe element is gone. Can water softener be attached to the inflow of the tank to descale softening the water now or going forward?
    Sergeant:
  • 306 Answers
For this problem , if you have a multimeter and a modicum of knowledge you can (carefully!) check for voltage at the element yourself. multimeter may show the timer was at fault so tat u can replace it and make it run!!
Posted on Nov 09, 2008
  • AbdulRahiman S Nov 09, 2008
    Else You need to check there is power going to the immersion by removing cover and using a circuit tester. I f you have power, chances are the immersion the has had it. Go to your local DIY shop and buy a new one. They come in two sizes 7'' or 14''. To find out which one yours is you need to turn off power and remove the thermostat, the thing in the middle that moves. Undo screws holding wires in place, then you can remove it. Go to shop amid buy the thermostat fit it and see if it works. If it still doesn't you will need to remove the heating element with a special box spanner, after draining the tank, remember to turn off the supply to the hot water tank. Go to shop buy heating element and fit taking care to connect wires the way you removed them.
    Genius:
  • 1,550 Answers
Have you checked current flow to water heater element .
If the water is cold and there is no current, then you have a bad thermostat.
  • 19,396 Answers
That is probably a faulty heating element, test the heating element for continuity.
  • Ginko
    Ginko Nov 09, 2008
    If this does not heat at all, then removing the scale will not work.
    The problem is probably the heating element ( a resistance) , that after so many years of service had probably broken and must be replaced, that is within normal maintainance standards, considering the age of the heater.
    The elemt cost is usually below $10, and the labor is around $80, still worth to repair.
Main fuse tripping
remove the cover from the heater spray with wd40, wipe dry, replace the cover and re-try
Dec 15, 2013 | Computers & Internet
Can I run the hot water heater with a generator
Yes.
Ordinary electric water heater can run on any voltage from any direction (excluding volt/amp ratings below what can heat element coil).
Voltages include single-phase, split phase, and 3-phase residential/commercial voltages with either 50 or 60 Hz.
http://waterheatertimer.org/How-to-wire-water-heater-for-120-Volt.html
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html#3-phase
Install line fuse.
30 amp fuse would be required to prevent wires from overheating, and eliminate fire hazard.
This information does NOT apply to energy-smart electric water heater with box on top of heater, or newer energy smart with electronics, or to hybrid water heaters, or heat pump water heaters with delicate electronic circuitry.
Why it works like this:
Ordinary electric water heater thermostats are mechanical bi-metal switches and respond to tank temperature, and are not operated by electricity.
Ordinary generic elecrtic water heater thermostats switch electricity on-off using mechanical bi-metal switch.
Heat elements are simple coil of thermal wire that gets hot when voltage is applied.
The element will get hot when power is applied.
Oct 29, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I was driving my 2000 Pontiac Montana with my heater on then all of a sudden it stop blowing hot air. Only cold air would come out of the vents.
ensure the coolent water level in your car system is full.
the heater radiator is set higher than the main system so when the water gets low there
is none in the heater.
as the fault came suddenly it also maybe the heater control switch or the thermostat has a problem
and has shut off the heat. check fuses to ensure there is not a problem there.
I hope this was helpful.
May 23, 2011 | Pontiac Montana Cars & Trucks
I have recently had a Howden domestic immersion
I would not have both on at the same time . We never did .
Oct 30, 2017 | Water Heaters
I have a HB Water cooler Model 2312C, Type WD01,
Problem: Water is not hot
Possible Causes: Dispenser is unplugged
Solution: Push plug completely into outlet
Possible Causes: Heating switch not on
Solution: Check to be sure heating switch is turned to ON
Possible Causes: The fuse is blown/circuit
Solution: 1. Replace house fuse or reset breaker is tripped circuit breaker.
2. If too many items are plugged into a single circuit, move some items to a different circuit
Possible Causes: Temperature limiter tripped
Solution: 1. Set the hot and cold power switches to OFF
position.
2. Wait five minutes, then set switches to ON position.
3. Wait 30 minutes for water to heat or cool
Link for owners manual: http://useandcares.hamiltonbeach.com/files/840178800.pdf.
Feb 18, 2010 | Hamilton Beach Water Cooler with Storage...
My immersion heater keeps tripping out and we have no hot water or central heating, blowing the fuse every time. could we need a powerflush ??
You have an electricl shortage in the system since it keeps tripping or blowing a fuse. Would suggest having system evaluated as soon as possible to prevent any further damage or injury. Good Luck on your repairs
Dave
Oct 20, 2009 | Carrier TSTATHCP Programmable Thermostat...
Electric immersion heater keeps cutting out
Sounds to me like you have a bad thermostat. You should be able to give a model number to any local plumbing supply place and get one for replacement. make sure power is of the unit before replaceing.
Feb 02, 2009 | Carrier TSTATHCP Programmable Thermostat...
Heating & Cooling Logo
318 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
