Question about RCA 27V530T 27" TV
Problem with the volume
Hi, when I turn on the TV, the volume goes all the way up to the max and it stays like that. Even if I lower it down it will go up again by itself. I tried to use the remote and look in the menus for an answer but every time I go into one menu once again the TV by itself moves the settings It is working like if someone were permanently pushing the up volume button in the TV set. Thanks for your help
    Sergeant:
  • 337 Answers
Two things can cause the problem your set has,one is the volume up button in the front of the set is pushed in too far and it has the momentary switch active all the time or the cleaning solution you use to clean the face of the tube has dripped down thru the lower edge of the frame into the switches creating a short and making again the switch active all the time.If the cleaning solution went down to the switches they will need to be replaced.If you are familiar with tv service you can remove the back cover and check that the button is not pushed in or it has corrosion built into.If you are not too familiar with tv service be safe and take the set for repair,if they come to your home it will be more expensive. Let Us know if you need more information.
Posted on Oct 27, 2006
  • Omar Urrutia
    Omar Urrutia Oct 27, 2006
    Your rating response is also important.
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
Volume moves up and down by itself and then stays max volume
sounds like the main system board is kaplooiee..
well..do you like to dig into this sort of thing?..it will take around 400 and 2 to 3 hours..
Oct 28, 2008 | Mitsubishi WS-55511 55" Rear Projection...
How do I keep tv from going to max volume and staying there
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 29, 2014 | Televison & Video
Coby tv sound problems
Aug 26, 2014 | Coby 40 TFTV4028 LCD TV
Cannot lower volume on my sony tv 32L5000
The electronic volume control section circuit is faulty. The system control section tries to adjust the volume, by sending command voltage to the volume control section circuit, but this circuit do not accept or process it. Troubleshooting to this type of fault, is skilled one. Contact any service technician, or the service center.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Timeslide" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 20, 2014 | Sony Bravia L-series Kdl-32l5000 32-inch...
Volume goes max and will not lower.
Hello
Please remove the batteries from the remote and check whether it is possible to use the local keypad on the TV? If the volume increases, it may be a problem in the local keyboard.
Apr 02, 2014 | Samsung LN32B550 32 in. LCD HDTV
Volume controll is going nuts.
Hi Manuel
I suppose the problem of your unit is memory, sometimes this problem can be fix by applying service mode, but if not, then memory should be replace and I would advise you to send your unit to service center.
Jan 16, 2014 | Televison & Video
Volume control
Poltergeist in volume circuit is the diagnosis. Try a hard reset of the receiver to see if that does the trick with the electronics.
Sep 01, 2017 | Mitsubishi WD-82737 82" DLP TV
The volume to the tv goes to max when you turn it on?
that hapened because your remonte contral has the + button pressed just release the volum + at your remonte and all will be ok
or try to hide your remonte control and get down sound from front panel of your tv
Dec 11, 2008 | Televison & Video
Tv volume goes down of its own accord
Some dust in the button to lower the volume on your TV or on your remote control might be causing it to think it's being pressed. Try playing around with it, pressing it hard so as to relieve it of any pressure on the inside.
Jan 09, 2008 | Televison & Video
RCA 27V530T 27" TV Logo
144 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
