Question about Hitachi 61SDX01B 61" Rear Projection Television
Multi colored vertical lines - aspect ratio - on screen menu
I have three problems.
Problem #1 - At times when I turn on the tv, multi colored vertical lines appear across the screen. I have to turn the tv off, then on and the picture appears.
Problem #2 - I have the aspect ration locked it at 4.3, however at varying times it changes by itself to 16.9. Plus the picture sometimes disappears and reappears when this happens. Sometime it does this three or four times in a row. I then have to change it to 4.3 using the remote.
Problem #3 - The volume on screen indicator and all the menu items used to be in solid colors and readable. Now everything is broken up and hard to read.
Any ideas of assistance will be appreciated. Thank you.
  • NBBijou Nov 10, 2008
    No HDMI hookup. Main hookup is component video cables. Prolem #1 has been going on for a long time. Problems #2 and #3 within the last few months.
  • 728 Answers
Try hooking up a dvd player to the aux option and see if the lines still appear and see if the volume and the menu items are broken. If they do, you may have to get a new color video tube or a video output board. You will need to get this checked by a professional to get this repaired.
Posted on Nov 10, 2008
  • Jazz Boyce
    Jazz Boyce Nov 10, 2008
    Try doing a full tv reset by unplugging all cable cords and power cords and let it sit overnight. Then check it in the morning and see if anything changed.
    Genius:
  • 1,913 Answers
Check your cable connection.press the jack of cable again and reattach it with tv.
also check in remote and change to ntsv.
  • 320 Answers
Can you tell me if you have devices connected (like a cable box) via HDMI? It sounds like your aspect ratio change, color lines and loss of pic could be related to a handshake probelm on HDMI with a cable box
  • Any Guy
    Any Guy Nov 10, 2008
    OK It sounds like you may problems in the DSP section (digital signal processing) which processes the video before being sent to the display tubes. The fact that you are also seeing problems with the OSD and menu displays leads me to this conclusion. The incoming signal is converted to a digital signal then the OSD and menu info are added and then the signal is sent to the display. In your case, since your display is analog (picture tubes) it has to be separated into the 3 colors and then converted back to analog and sent to the tubes. You are going to need a technician to narrrow down exactly where the problem is occurring in the DSP section.
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Sony bravia klv40v300a lcd tv 6 time led bilink.what is the problem
It sound like it took a power surge. suggest you either have it serviced or replaced the tv itself. Frankly if it is not under warrenty then it is time to purchase a brand new tv.
Feb 20, 2015 | Sony KLV-40V300A Multi-System BRAVIA LCD...
I have multi colored vertical lines across the entire screen. The menu screen is perfectly legible when selected on the remote and will go on and off like it is suppose to.
If this tv vertical colors lines problems happen by itself,tv problems not causes by u or an object by hitting forces to the tv LCD screen panel itself.The tv board that call the T-CON board it is dead,this board sit in the bottom in the middle of the LCD screen panel.Must be replaced the T-CON board to solve tv vertical colored vertical lines.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacement.If causing by u or an object by hitting forces it to the LCD screen panel itself.The tv not worth a whole tv anymore,because by replacing the tv LCD screen panel will cost the same as a new tv.
Jul 28, 2011 | JVC LT37XM48 LCD TV
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Multi color vertical lines on sony wega LCD tv/42 inch
sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
Aug 11, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
