Question about LG DLP Projector 1400Lum RD-JT30 Multimedia Projector
Display of image between laptop and projector
The image on my laptop is not showing unless I move the window to the extreme right (off screen) - then it shows on the projector. I am desperate - I am training tomorrow and I won't be able to use my presentation. HELP!
  • 2,237 Answers
Change the resolution. the desktop is too big.
Posted on Aug 19, 2009
Elmo projector
sounds like you did not setup image screen.
Start
control panel
display
change display settings
multiple displays --- extend displays
detect - will show 1 &2 on each screen
apply
Apr 23, 2013 | Printronix T4M Dt/Tt 4-Inch 203 Dpi Rfid...
We can't seem to get the picture from the laptop to the projector
For Windows 7 and Vista- Close or minimise all windows, right click on the desktop and select "Screen Resolution". Press the "Detect" button and if another display comes up, on the dropdown menu labelled "Multiple displays" select either:
"Duplicate these Displays" to show the same image on both screens
or
"Extend these displays" to have 2 separate displays (the position of the second display can be changed by dragging the box labelled "2"
For Windows XP - Close or minimise all windows, right click on the desktop and select "Properties" and then the "settings" tab. Click on the greyed out box labelled "2" and Tick the box labelled "Extend my desktop onto this display". click apply.
May 04, 2011 | ViewSonic Office Equipment & Supplies
I can see my background but cannot see anything else
The Fn+F8 in some laptops or Fn+ KEYS WHICH HAS MONITOR ICON OVER FUNCTION KEY) command tyically runs through 3 modes: Extend desktop, Laptop only, Projector only.
Mirroring displays (meaning you see the exact same thing on both screens) is not always on option on a PC; the ability to do that is dependent on the graphics card and drivers in the laptop.
Not seeing the exact same thing on both screens is often the preferred way, but when you don't see all your desktop icons it can be a bit confusing.
The trick here is that when you want something to show on the projector, you grab the window you're working with and drag it over to the other monitor. Why this is preferred is because you can be showing a powerpoint presentation on the projector, while you have a script or notes open in Word on your laptop display to read from. You see, you don't see anything but the desktop background on the projector because you haven't moved anything over there yet.
Your laptop is in extended mode, try changing to Laptop mode, should solve your problem or try dragging the required file to that monitor as said above
Please leave me comment, if you need further assistance
RNJ VINODKUMAR
Oct 24, 2009 | Acer Office Equipment & Supplies
LCD projector not displaying image of the laptop
On that Dell, you have to tell the laptop to display the image on an external unit--look on either F4 or F8--you will find a small TV screen symbol. You have to press and hold "alt" and press the key. The options are, 1-show image on just the laptop, 2-show the image on the laptop *and* something else, (like a projector), or 3-show an image on JUST an external display. NOTE: Sometimes, you have to turn on the projector FIRST, then immediately turn on the laptop so they boot together--just one of those strange things...(remember, **for example** first press of "alt" F4 will get you laptop and projector, second press of "alt F4 will get you JUST the projector, third press of the keys will bring you back to just the laptop)---Rick
Sep 07, 2009 | Panasonic PT LC75U Multimedia Projector
I just purchased an Acer X1160 Projector and obviously am not savvy enough to understand what to do to make it work. When connected to my HP Laptop I get the image of my screen saver, but cannot get...
Your computer is probably using the projector as a second screen instead of displaying a copy of the laptop screen.
The quickest way to confirm is to try moving your cursor (mouse) off the right-hand side of the screen. Does it then show up on the projector? If so, then you can grab and move windows back and forth between the two screens.
If that solves it for you, please be sure to click the thumbs-up.
If not, add a comment and I'll try to explain
Sep 02, 2009 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
3M MPro110 will not display laptop display image
I changed my computer resolution to a lower value and this did the trick. I was also told that by doing this along with having the display shown only through the projector (instead of it being mirrored on both displays) should negate any problems. Thanx
Mar 20, 2009 | HP Pavilion dv2000t Notebook
PC connected to projector shows only in Blue
Are you saying that the projection is solid blue? Is it similar to, say, the desktop on the laptop screen? Try moving your mouse off to the right side of the laptop. Did it show up on projector? Exciting! Try dragging stuff over. Damn, this is sweet.
Feb 12, 2009 | HP VP6121 Multimedia Projector
Laptop computer connected to projector.
When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
But once you find your dual display options you will be able to change it to make both displays the same
Jan 21, 2009 | Dell Latitude D600 Notebook
Acer laptop stopped displaying to projector
Here is the deal. Right-click on desktop. Choose settings. Right-click on screen #2. Click on apply for new settings. The one additional problem you may encounter is the fact that the projector will display an area to the right of your laptop screen. In other words, move your mouse past the right edge on laptop screen. Look at projector image. See your mouse?
Aug 04, 2008 | Computers & Internet
Cannot display image on a proector using Lenovo laptop
Ok.I got your point.Actually you're in extended mode.
Once you connect you can have 2 types of output to your projector.
1.Clone mode--> make everthing look the same
2.Extended mode--> have another new space for you to use.
** in extended mode you'll have a background of your desktop.you can drag any running program to that space.
How to setup clone and extended mode
1.Click start-->Settings-->Conteol Panel-->Display
2.Under Display Properties window click the last tab name settings
3.Under display select you 2nd monitor
3.Below Screen Resolution you should be able to see a checkbox "extended my windows destop on to this monitor"
please check this box for extended mode or uncheck it incase you won't to use clone mode.
takecare.
Apr 28, 2008 | Computers & Internet
79 people viewed this question
Top LG Office Equipment & Supplies Experts
jasbo
jasbo
scj103
Jaime Hernandez
Are you a LG Office Equipment and Supply Expert? Answer questions, earn points and help others
