Question about O2 Xda II Smartphone
My O2 XDA II LCD touchscreen did not respond frequently
Sometimes my O2 XDA II touchscreen didn't responds at all, but sometimes it work normal. The problem usually happen after I switch off the power and let the condition for several time and when I try to switch on again, the touch screen was freeze and did'nt respond. But in that condition all the button was work normal, like camera button, voice recording button, phone button (hardware button). I try to solve the problem by did soft reset, but the procedure didn't guarante will be succes on the first try. I should retry the procedure for several time, and couldn't predict when will be successed. Is there a problem in ROM ? and I should do ROM flash upgrade ?
My orbit xda 2 has problems with the screen freezing and i don't know how to rectify the problem. The volume screen will not remove from the screen either, what gives?
Posted on Nov 08, 2008
I there, My XDA II has developed exactly the same problem and I think I have descovered what the problem is... My XDA as a very small gap between the screen and the plastic case, I noticed that a piece of grit gad got in there and I used the corner of a piece of paper to try to remove the particle. I was unsuccessful and only managed to move the piece of grit up to the top right hab corner of the screen. Imediatly after this I started having trouble. I have now found if I push the plastic case into closer proximity to the screen I starts to work again. Please try this and see how you get on. It may be that I have to have my screen replaced!! Or at the very least the dust etc cleaned out from around the screen.
Posted on Nov 02, 2006
How can I improve the touch of my screen it takes forever to respond
Hi it's possible youre tablet has a faulty glass screen digitizer ,cheers
Sep 06, 2016 | Tablets & eReaders
My LG KU990, touchscreen not responding to any commands. what do I do please?
sometimes the touchscreen will fail, normally it's the initilizer. these can be purchased cheaply from E-bay however will mean a partial dismantle of the phone! be careful as these are glued and screwed in.
Oct 18, 2009 | LG KU990 Viewty
Screen on my O2 mini xda II doesn't work; hear the program works but the screen is completely white.
if your unit has been dropped or been in your paocket and got wet by perspiration/sweat, you need a new lcd module. buy a new one and have it installed by a certified technician.
May 19, 2009 | O2 Xda II mini
Xda II - no sound/speaker
It may be speakers connector got removed from the board.
Jun 01, 2008 | O2 Xda II Smartphone
The screen won't respond
format your phone and reinstall the os once again...
this will sort the problem
all the best
Nov 20, 2007 | i-mate Pocket PC
O2 XDA II mini fell down
your unit experienced shock. due to fragility of the phone, your LCD might be broken, if not, the LCD connector needs to be refitted to its slot. If the problem is still the same, you need to replace ur LCD.
Oct 25, 2007 | O2 Xda II mini
O2 Pocket Pc stopped working after upgrade installation
flash arom directly from bootloader mode (by pressing camera ****. and keep press. then press with sylus the soft reset ****. ,
then the 3 colors shows with usb in left bottom site of screen of device then run the flash utility normally .
May 06, 2007 | O2 Xda II mini
02 xda II s pocket pc pda
Upgrade ur ROM to latest version. it will help I think.
Jan 14, 2007 | O2 Xda IIs Pocket PC
REPLACED FULL SCREEN NOW ONLY WHITE SCREEN
hi there
your phone is in bootloder mode....you need to format the phone and if required you can install the os again..
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Nov 09, 2006 | O2 Xda II Smartphone
O2 Xda II Smartphone Logo
587 people viewed this question
Top O2 Computers & Internet Experts
zurysk8
Level 1 Expert
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
