Question about Sharp CD-PC3500 CD Shelf System
Sharp CD PC3500 CD Shelf System CD track jumps and doesnot complete song
I have Sharp CD PC 3500 self system. Everything is running fine except CD player. Either it cannot read CD or if reads, cannot complete track. It jumps to next track after few lines. I cleaned head so many times. It did not help.
If you do not mind, also send me email to snehalsuvarnkar@yahoo.com showing solution
  • 2 more comments
  • snehalsuvarn Nov 09, 2008
    This is my first visit to the site. So I do not know what to comment on. May be next time.
  • Anonymous Nov 24, 2008
    The stereo will attempt to find a cd or will just give an error message.
  • Anonymous Nov 25, 2008
    same thing
  • mattoudoux Nov 25, 2008
    the same problem
It seems tht u have a faulty lazer which is common in these types of stereos try smeering **** over it or eating it if it dnt work u will still feel much beter about yurself
Posted on Nov 09, 2008
Cd doesn't spin
two possible reasons the disc will not spin.
1, wire disconnected inside from the motor
2, the motor needs to be replaced
If the device has an AUX or Ipod input you can use an external CD player, just know the cost of repair will not justify it however if your savy with the tools it mite be worth it to you.
Mar 15, 2011 | Sharp CD-PC3500 CD Shelf System
How do i unprotcet my cd-pc 3500
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 23, 2011 | Sharp CD-PC3500 CD Shelf System
I have sharp cd pc3500 stereo system when i turn the power on the message on the screen shows PROTECT. I cant do anything nor any function work
Make sure the speaker wires aren't shorted together and that they are not freyed or cracked...the unit is in protect due to it's internal circuitry sensing a shorted output condition...this is in place to protect the unit should the speaker wires become shorted together. You can remove the speaker wires entirely and then turn on the unit to see if it comes on...if so then I would look at each wire carefully to make sure they look good..of course if the unit comes on and the wires look good then you may have a bad speaker component...Now, if the unit stays in protect after you unplug the speakers, then the unit probably has a blown audio output stage inside the circuitry and will need to be serviced.
Jan 05, 2011 | Sharp CD-PC3500 CD Shelf System
I have burned cd and my sharp cd-c444 wont play it. why
Check what format you burned the songs from. Some formats, like MP3, mpg, among others will not play on all stereo systems. When you burn the songs, make sure that MP3 is not the format for the Sharp system, and that in fact, mpg is. I hope that solves your problem.
Sep 27, 2010 | Sharp CD-C444 Shelf System
Protect mode can't use any buttons need the senquence in order to unlock the system
most sharp reset by pressing the power button to enter the power stand-by-mode while pressing down the volume down button ,press the power button un-til ALL CLEAR appears...hope this helps...yammandan
Aug 19, 2010 | Sharp CD-PC3500 CD Shelf System
Hello, my CD skips after playing 5 songs and then ...
Have you tried cleaning the lens tracking gears with some gear grease? That is most likely the problem. The lens is fine reading the first 5 tracks but when it gets to the 6th one it will start to struggle as it cannot adjust the angle to the correct part of the cd due to the gears or the lens rails been dry or clogged with dust.
May 20, 2010 | Tivoli Radio Combo CD/AM/FM System Shelf...
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Nov 09, 2007 | Emerson MS9700 CD Shelf System
PROTECT
The audio output ic's need to be replaced. need to contact and audiotech to do the job . the job require experience to be done. around 60.00 in parts . if you need more help let me know.
Jun 21, 2007 | Sharp CD-PC3500 CD Shelf System
Sharp CD-PC3500 CD Shelf System Logo
171 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
