Question about Sony BRAVIA KDL-40V3000 Television
Kdf-e50a12u red light blinking
My tv will not switch on and the red light flashes twice can u help?
  • 2 more comments
  • watersss Nov 09, 2008
    still the same didnt work.
    it has been unpluged for hours now and the red light still flashes twice.
    would it be cheaper to buy a new tv?
    no
  • 905 Answers
Are you able to do some electronic component testing?
Posted on Nov 09, 2008
  • jason Nov 09, 2008
    it will cost to get it fixed but not as much as another tv
    as much as it costs for another tv , you would be better off getting this one repaired
    Scholar:
  • 112 Answers
There is definitely a power problem. It will probably wave to be taken to a repair service and fixed.
  • Sony Master
  • 19,396 Answers
The TV is in protect mode.
Try unplugging power cord for ten minutes or so, and see if this help.
If the TV does not restart, then try unplugging for longer.
If still no luck then that means that there is an internal fault, let me know if you get the led blinking a number of times, or if there is an error code message on the TV display.
  • 3 more comments
  • Ginko
    Ginko Nov 09, 2008
    In particular , regarding your case,
    TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
    mode then displays the 2 blink fault. Could be a short in the power supply of
    any of the circuits.
    That means that if the TV does not restart after unplugging overnight, that means that the power board must be replaced.
    Note: it is not the main fuse, when it is the fuse you get no power at all, 2 blinks means : protection after overvoltage from power adapter.
    Often you fix this by leaving TV unplugged for some hours, until you drain power completely.
  • Ginko
    Ginko Nov 09, 2008
    If it is still the same, wait longer.
    If the over voltage had been occasional (eg. power surge can give you this) , then after draining power completely, TV will restart.
    This is only if you are lucky enough and TV is not broken.
    If TV does not restart the bad voltage that started protection circuit (led blinking and TV not starting), was caused by a bad power board, probably one of the 3, 5 or 7 (depending on network voltage and model) high voltage capacitors on power board.
    In this case the TV keeps in stand by so that the protection switch can save the rest of the circuits from being damaged by a faulty power board.
    If it does not restart, you will need to call a technician to fix it.
    You can call support by ringing the phone number listed on the owner manual.
    If you call Sony, ask them also the cost for a warranty extension, this is generally less expensive than a single repair job, and can cover all repair costs for one extra year.
  • Ginko
    Ginko Nov 09, 2008
    You can refuse my opinion, but I think I have been enough clear, the TV has a malfunction related to a power board problem, and must be fixed by a qualified technician.
    I also re-post my previous comment for better clarity:
    If
    In this case the TV
    If
  • Ginko
    Ginko Nov 09, 2008
    No what? You have a faulty power board, 2 blinks, and no restart after har reset (unplugging procedure) is just a faulty power board.
    Here is the faulty part, if you have a good experience in fixing electronics, then you can do the job yourself, if not call the technician.
    And no what!?
    Here is the part:
    http://www.pronto.com/1-866-356-13-PCB-p...
    If
    In this case the TV
    If
  • Ginko
    Ginko Nov 09, 2008
    And do not forget to ask Sony the cost of guaranty extension, it will be probably cheaper than the cost of the single part.
    Thanks for using Fixya.
    Here
    technician.
    Here is the part:
    If
    In this case the TV
    If
    Genius:
  • 1,550 Answers
Check the fuse?
It might be burnt .
  • SAM ANDERSON Nov 09, 2008
    H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted.
Kdf e50a12u powers off
It might be the ballast or the heat sensor in the light chamber.
Jan 05, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Sony kdfe50a12u red light flashes twice and wont turn on.
Go to this website for blinking codes. Also you can bring the onscreen diagnosis test up by pushing on your remote set, 5, volume- and power. Make sure the tv is off when doing this. http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Feb 25, 2013 | Sony KDF-E50A12U 50" LCD HDTV
SONY KDF-E50A12U TURNS ITSELF OFF AND FLASHES POWER LIGHT RED 4 TIMES HELP PLEASE
the 4 blinks on that model are indicating the set isnt starting due to a problem with the fan,
Aug 06, 2012 | Sony KDF-E50A12U 50" LCD HDTV
Sony kdf-e50a12u my tv flashes the green power light only
How may flashes the LED does? This error code will tell you what is the problem.
Aug 02, 2017 | Sony KDF-E50A12U 50" LCD HDTV
I have a KDF-E50A12U Sony TV it won't turn on and keeps Flashing red twice, no other lights are on, just the stand by continually flashing twice.
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Oct 30, 2009 | Sony Televison & Video
Sony BRAVIA KDL-40V3000 Television Logo
404 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
