Question about Acer Aspire 5720-4230 Notebook
I can access internet only by yellow cable, not wireless?
I can only access internet via yellow cable. The laptop is WLAN enabled but throws up error when I try to go wireless. It tries to repair but it still only works when plugged in directly to BT Voyager Box.
  • did you press the fn key and the (((( f key has the unit been serviced or taken apart at all there is a wireless card in bottom that has to wires connected to it that run up the lcd
    Scholar:
  • 75 Answers
Try updating the driver for the wireless card or uninstalling it then reinstall it what version of windows?? vista has a problem with wireless routers loosing connection randomly because of the broadcast flag in the registry ... if you have vista might be worth looking into if the driver isnt it
Posted on Jul 24, 2009
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
-unable to connect to wireless -unable to open internet explorer msg states "unable to connect due to error on this site" (yahoo) -Is there a reset botton for wireless -Called my internet Co,...
Your problem may appear from a not properly enabled WLAN card.
Make sure the Wi-Fi swithc is in ON position and on your laptop keyboard try the FN+F8 combination to have displayed the wireless card status. The WLAN card has to be ENABLED to be able to connect to the Internet. The combination done will make appear on your display a window with some options available; choose that option that enables your wireless card.
Also check in your computer's DEVICE MANAGER if your WLAN card is working properly. To do so follow these simple steps:
1. START and click on SYSTEM;
2. in SYSTEM option click on DEVICE MANAGER;
3. on DEVICE MANAGER option go at NETWORK ADAPTERS and see if there your wireless card is indicated and it shows that it is working PROPERLY;
4. if an UNKNOWN DEVICE is indicated then try to find the right driver for you notebook model and WLAN card model;
5. install the driver then REBOOT and recheck in DEVICE MANAGER if your WLAN card is displayed properly this time.
Mar 02, 2011 | Toshiba Computers & Internet
Wirless connection wont connect to network.
On the WLAN world, exist a encryption key for connection. You will be able to see the "antenna", but until you enter the key you will not be able to access the network or the internet. First, disable the wireless security and try. Once you have verified the connection to internet then you add security. Use WEP.
Jul 06, 2009 | NetGear WG602 802.11g/b Wireless Access...
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless network connection problem
Ok with a peripheral on USB or on PC card bay you can try to connect to a Wireless lan:
Please check this tip on the subject
To connect to an existing WLAN you must be sure your wireless card is working: I assume you installed all the related sw coming with the wlan card.
Using the card installed driver check card is enabled and running (in Control Panel/Network connection should be visible and enabled)
Then you can connect to an open Wi-Fi HOTSPOT or to your WLAN you configure with a router connected to your internet modem.
  1. To connect to an existing HOTSPOT: find a location where you know a wi-fi access point (HOTSPOT) is active: Internet cafe,, library, airport,, station, hotel etc.your card should be able to find the existing network when you select "show existing network" in wlan driver. Connect if network is "unsecure" (= no password or key is required) or ask for password if you can get it for a fee (hotel)
  2. To connect to your home or office WLAN be sure to use a router (or access point) with same standard of your card (802-11G or B or A or N) with same security protocol (WEP or WPA) and configure your router Internet access BEFORE wireless access. Connect your PC to your router using a LAN cable and be sure you can browse through the router.(contact your ISP for router specs if you need it: PPOA/E and other). Follow the tip and your router doc for settings
Jan 14, 2009 | HP Compaq Evo n610c Notebook
Laptop says excellent connection - not able to access internet
connect laptop to router using lan cable.
check internet connection. Should be ok.
Only then enable wireless using same WLAN protocol you use on Router: WEP or WPA with same encryption key TKIP or AES.
Be sure no access list enabled on Router or add Laptop MAC address to access list.
Dec 28, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Acer Aspire 5720-4230 Notebook Logo
158 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
