Question about Hotpoint RLA30 Compact Refrigerator
RLA30 Fridge freezing food on lowest setting
The thermostic control on my RLA30 seems not to be working even on the lowest setting of 1. Any advice please. Do I get a repairer in from yellow pages or sign up to an account with some one like D&G for 12 months at a rate of £13 per month and get instant repair
  • Hotpoint Master
  • 3,463 Answers
From the symptoms ,I would recommend that you have a new thermostat fitted.
This is the cheapest option., fig's do not go wrong that often
Any comment welcome.
Thanks and a merry xmas.
Posted on Dec 20, 2008
Top of fridge freezing with temperature on lowest setting
You need a new thermostat but there are some things you can check in the link. 1 is the warmest setting.
Most refrigerator temperature settings are controlled with a dial or slider. They are sometimes labeled 1 through 5 or 1 through 9. If you are not sure what to set it to, then set it somewhere in the middle. If the dial is numbered 1 to 5 set it on 3, if the dial is numbered 1 to 9, then set at 4. USUALLY the higher the number on the temp control dial, the colder the temperature your refrigerator will get. If your drinks and food are not as cold as you like, set the temperature dial up one number higher. If it is at 3 and you want your food colder, set it to 4 and test 12-24 hours later to see if your food is at the temperature you want.
Why Is My Refrigerator Too Cold
Dec 18, 2016 | Refrigerators
Everything freezes
Make sure it is level.
Nov 25, 2013 | Hotpoint Refrigerators
My fridge keeps freezing everything even on the lowest setting - does it need a new thermostat?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Aug 25, 2010 | Hotpoint RLA30 Compact Refrigerator
Food keeps freezing in my fridge. Even at the lowest temp.
in the fridge compartment check behind the control panel where the light bulbs are remove this cover and make sure the damper vent door opens and closes when adjusted with the fridge control sometimes they ice up from condensation and freeze in one position and this may let too much cold air in from the freezer for too long,otherwise it also could be a defective electronic control board in this same area
May 13, 2010 | Jenn-Air JFC2070KRS Stainless Steel Bottom...
Fridge is freezing
there is a way to adjust it but its very to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
How to change the thermostat on a Hotpoint RLA30 fridge
It is behind the knob your are adjusting to change the temperature.
It is very easy for me. Don't know how easy for you and your electrician friend.
Apr 20, 2009 | Hotpoint RLA30 Compact Refrigerator
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Hotpoint RLA30 Compact Refrigerator Logo
410 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
