My naim audio cd 3.5 cd player does not always start when i load a cd in, sometimes you need to open and close the transport door many times before the disc spins and the cd detects the number of tracks etc
bluenadas
  • 203 Answers
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Posted on Nov 21, 2007
HDTV GURU
  • 261 Answers
SOURCE: DVD player not working
It could be that the DVD player has a bad home switch in the dvd player or that it doesn't know that the door is closed. I have run into similar situations with CD Players years ago. Also keep in mind to unplug unit and let sit for 1 minute to let microprocessor reset. Let me know if that helps. Thank you ...Jay
Posted on Jan 31, 2008
robotek
  • 1512 Answers
SOURCE: Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Posted on Mar 16, 2008
petraman7
  • 1175 Answers
SOURCE: 3 yr Old CD Player not recognizing discs
Laser might not be faulty but just a dirty lens/ rail assembly.
If thou darest open the thing, clean the lens ( GENTLY) with a swab of glass lens cleaner. Clean the chrome runners for the optics assby with a swab lcaed with WD40 or silicone.
Posted on Jun 26, 2008
SOURCE: Marantz cd 63 player has
Cleaned laser lens carefully with a cotton bud dipped in isopropyl alcohol. Waited for it to dry before trying. Success!!
Posted on Aug 24, 2008
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer ยท CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
The CD trays on my Fisher DAC-199 will not come out. The machine just hums. The door will sometimes open or close.
That is most likely a belt that has stretched with time. Some belts are easy to install and other are so that you must remove the transport to get at the belt location. The symptom is very common in belt type drawer systems. I see it all the time.
Dec 08, 2012 | Audio Players & Recorders
Cambridge Audio AZUR 840C Transport Jamming when disk is loaded
The above comment is complete and utter nonsence !
Here's what you do . Take the lid off , take off the top of the cd transport marked "CD 1 Low Jitter Compact Disc Transport" held on with 2 screws , rince it under warm water (its made of plastic) and refit . Its a build up of dust . Yoy will have to do this every 2-3 years . P.S Leave on "stand-by" because you will do more damage to the circuit boards by cutting the power continually .
Sep 15, 2012 | Cambridge Audio Azur 840C CD Player
Tray error on a denon dn 4000
The cd transport is up the swanny (broken , kaput).
take it to your nearest registered denon repair/service centre
Sep 05, 2012 | Audio Players & Recorders
The gears are jammed, or the timing gear is out of sync, and possibily a bad loading belt.
May 20, 2012 | Philips Audio Players & Recorders
Door keeps opening.
Replace the loading tray belt, it is quite a common problem on CD Players using the same Sony transport mechanism as your Arcam.
The belt loses its tension and cannot fully load and then spits the tray open.
When you try to load a CD you should be able to hear a whirring sound after closing the tray and that's the motor trying to lift the laser mechanism at full travel but is unable to hence not enough tension on the belt.
Hope this helps.
Jan 18, 2011 | Arcam Alpha 7SE
I own a Philips CD 950 player. I now cannot open or close the CD compartment. How do I remove my disc? I live in Manhattan, New York City and wonder if there is a service center near me.
The small gear that opens or closes the door goes bad after 10 or 15 years. The gear is not available separately. The solution is easy. Take the deck cover off with a torx bit, and remove the broken gear pieces. Push the CD transport door out, and fasten heavy clear mailing tape on both top and bottom of the center of the CD transport door to make a Grab Tab you can use to pull the door open. When you load the CD you are going to hear, push the door open/close switch twice to fool the deck to go into PLAY mode. Mine has worked great like this for 6 years now, and it still sounds beautiful.
Oct 03, 2010 | Philips Audio Players & Recorders
The player only intermittently recognizes CDs inserted; it does not seem to make any difference whether they are commercial, recorded at home, etc. Sometimes it says "insert disk," sometimes "no disk." ...
A CD tray is usually powered by a rubber strap, the belt can slip through, causing the electronics to miss the input timing, including a microswitch or copper contact which is activated at the closed disc tray so that the laser is focussed to read the table of contents Due to the fact that the spindle motor is activated. And in some players (interchanges there is also a selects witch that can be contaminated. a suggestion to help in the link
How to Fix DVD or CD Player That Won Open
Jun 30, 2017 | Philips CDR950 CD Recorder
Cd disc player will not play
Reset the drawer timing. The door switch is not working properly.
Dec 16, 2017 | Audio Players & Recorders
My DCD3000 door closes automatically and won't read discs right
Hi....
If the transport inside is like the NAD players, it's the drawer belt that's the problem.
Belts are cheap but someone technical needs to change it.
Mar 24, 2009 | Audio Players & Recorders
 Grubhead
Grubhead
