Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Epson stylus dx4000
My printer is showing ink low but i am unable to get the cartridges out of the printer what do i do
    Genius:
  • 1,913 Answers
Pull your cartridges u can do it.
Posted on Nov 09, 2008
Epson Stylus DX4000 printer not working
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-DX4000-printer/Drivers-Support?supportLandingPage=true
Mar 20, 2010 | Epson Office Equipment & Supplies
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
My epson dx4000 Cannot recognise ink cartridge. i have tried new epson cartridges and compatible ones but nothing seems to work. have also cleaned heads manually as printer won't do it thank you for any...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Dec 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus dx4000 printing blank pages . how do
replace cartriges, clean printers heads from utility menu
Oct 25, 2009 | Office Equipment & Supplies
I just changed the black ink cartridge (Epson) but
geh mas nek iso kowe tuku printer maneh ..opo ra duwe duit go tuku maneh,,,piye to...jere sugh.....nek ora duwe duit ngepet wae to
Aug 11, 2009 | Epson Stylus C86 InkJet Printer
Epson stylus c64. Replaced low ink printer
1) Unplug the power cord, wait 30 seconds, then plug back in.
2)Did you follow the directions exactly when replacing the cartridge? Did you peel off the protective film?
Jul 03, 2009 | Epson Stylus Photo R300 InkJet Printer
My Epson Stylus C43SX does not print without the black ink
I sympathise with your frustration - we all feel it. Epson printers, by design, will only work if all cartridges are present and correct. When you change a cartridge or carry out a head clean, the ink charging and head cleaning is carried out on all cartridges. So what you are experiencing is normal, I'm sorry to say.
My advice is to buy the cheapest compatible cartridges you can get - have a look at e-bay in particular. In the UK a set for the DX4000 would cost less than 6 UK pounds, including shipping. If you are prepared to buy several sets at once you can save a lot more.
Note for future reference that your query was in the C43SX section - make sure you post your queries in the right section, otherwise people who could help you may well not see it.
Oct 18, 2008 | Epson Stylus C43SX InkJet Printer
Epson stylus cx5000 series
i cleaned the post where the ink cartridge slides down on with alcohol. they could maybe be called the print heads i am not sure. but it is for sure this model cx5000 loves ink!
Aug 18, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Changing Ink Cartridges
I'm assuming you are using originals. I would suggest you taking the cartridges out and re-inserting them. If you are using refilled cartridges and you used the cartridges to almost empty then probably the chip may have short circuited rendering the chip useless. If you bought remanufctured cartridges I suggest you ask them for replacements. This isn't really that high tech but I hope this helps.
Jul 15, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
