Question about HP Color LaserJet 4600n Printer
Printer not "seeing" cyan cartidge
I replaced the cyan cartidge, but it's not being seen by the printer. I have removed and replaced all the cartidges, transfer kit, turned it off then back on. Any help would be appreciated. Thank You
  • 1346 Answers
SOURCE: HP Remove and check cartidge
usually, the error is because it's not recognizing the cartridge. Check the contacts on the printer and clean w/ alcohol. Are you using recycled cartridges or filling it yourself?
Posted on Oct 11, 2007
  • 55 Answers
SOURCE: No Paper Pickup
turnoff the printer n reseat the tomer catridge properly ,take care it should not be tilted on side,check it that it seated properly,power on the printer n check ,can u hear any motors moving sound,if yes check the printer now,if not check for any peice of paper inside the printer especially from where the paper comes out
do revert
Posted on Jan 28, 2008
SOURCE: No paper pickup
Hi , I just had a same problem with the HP Laser Jet 3055 printer at our office but I fixed it! try this:
Turn off the printer.
Open the printer door.
Remove the Cartridge.
Look down behind the cartridge, there's a small white roll. Try playing with it. move it back and forth. try emptying the paper tray and place it back in the printer.
Turn on the printer.
I did this and for some reason it worked! GOOD LUCK!
Posted on Feb 07, 2008
  • 1029 Answers
SOURCE: 970cxi hp printer
the PCA is held to the carriage /cradle by usually one or more screws. sometimes these loosen over time, so while the contacts on the PCA and the ink cartridge look ok, they're not actually making good contact. try removing the pca from the cradle, and reattaching it, making sure you torque the screws down firmly (but don't crack the board). sometimes a small washer or shim helps to get the board closer to the carts.
many times if you look along the top of the cradle/PCA assembly, you will notice that the gap between the board and the cradle is not uniform. this is usually a dead giveaway, and snugging up the screws will usually fix it.
also if you closely examine the cartridges, you may notice that the indentations or scratches on the contacts aren't uniform which may also point to a skewed PCA.
Posted on May 17, 2008
  • 390 Answers
SOURCE: how to refil ink in hp 2120 cartidge
try also resetting the ink levels once ink is flowing out holes. If ink is not blotting from cartridge onto unscented wipe, you may need more ink to let ink get to bottom, to force air bubble out. Half filled ink will create bubbles. Try blowing into ink refil hole also. When ink is free flowing out printer end, you know it is ready to go, and reset cartridges on printer too (ink levels) cheers lilacgerry
Posted on Jul 31, 2008
  • 10 Answers
SOURCE: Ink Refill for HP Photosmart c7280 not working
Hi Lisa,
If it responds ok with the old cartridge then the problem is with the cartridges' chip not the printer. Probably the manufactor has a problem with certain cartridge chip (contact them!). I would suggest to use the original at the problematic spot if it works without a problem.
- Gilberto
Posted on Jan 05, 2009
0 characters
1 Points
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
88 replace cyan cartidge in Lexmark C540n what i have to change
You need to change the Number 88 Cyan Cartridge on the Printer!!!!
Aug 29, 2011 | Lexmark C540N PROD SPECS TBD Printer
Brother MF 5440CN USB Printer won't print. Says "Ink Empty Cyn" and then "Ink Empty Yellow" Replace Ink There is ink in the cartridges.
While there may be ink in the cartidges, your printer is getting a signal from the cartidge that it's near empty. There is no real workaround for this; you just have to replace the cartridge(s). If you use a LOT of ink, you might consider installing a CIS (continuous ink system) now made for most printers. You will save a lot of money over time.
What you describe is typical.
Dec 06, 2010 | Brother MFC-5440 Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
The cyan and magenta cartidges have run out but I cannot print in black only, since a staus window appears telling me to replace cartridge the cyan and magenta and will not let me continue to print in...
You can't print in black only mode because printer need all cartridges not empty to initialized and working.Don't try to refill this cartridges, it's have a chip and you need to reset it too.Just look in your are for non OEM ink cartridges.Thea are 2-3 times cheaper.
Nov 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Problem with refilled HP 27 cartridge
remove some ink from the cartridge and clean the contact point of the cartridge and inside the printer, then hold the cartridge. when the cartridge not drop ink fix the in the printer
Feb 27, 2009 | HP Printer Cartridges (Complete List): ,...
Minolta 2400W - Put cyan / black toner
hey, the problem is that toner cartridge reading chip is dirty.
take out Pc drum and remove all toners, clean toner chips with alcohol. then locate a 3 pin reading chip under the toner rack left side and use pressure air to clean it. reinstall everything. if its not helping, replace the chip, its not expencive
Jun 28, 2008 | Konica Minolta magicolor 2400 Laser...
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Printers & Copiers
Ink cartridge cyan is not working
Beside of the color ink there are photocouplers, check them
May 14, 2008 | Brother MFC-5840CN All-In-One InkJet...
?I know there is ink in my cartidges but it wont let me print arrgggghh
even if you are printing only in black, some colours would be mixed. and the main color that is being used for this purpose is cyan. so you will have to change the cyan cartridge to get rid of this problem.
thanks and regards
Mar 12, 2008 | HP Photosmart 3310 Printer
HP Color LaserJet 4600n Printer Logo
16 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
