The laptop key in between E and T has stopped functioning
    Scholar:
  • 112 Answers
Take a look with a flash light around the edge of the key. There may be something in there. About all you can do is completely shut the computer down (NOT DOING THIS FIRST MAY DAMAGE YOUR HARD DRIVE) Carfully and gently tap and very lightly shake the computer, then look again. Again this should not be done very aggressively. If you can't find anything and it still doesn't work, you will probably have to have the keyboard placed. The only other thing you can try is taking a compressed air can and lowing it out. If this does not work, you can take out the keyboard (preferred only if you know what you are doing) or take it to someone that does know what they are doing.
Posted on Nov 09, 2008
    Genius:
  • 1,250 Answers
You can connect a usb keyboard to your laptop and do your work, for the laptop key take it to the technician and check it there he will better tell you
My arrow keys aren't working, only the FN function even when not being pressed
Either you have a stuck key, or your keyboard is shorted maybe due to liquid being spilled into it. Lightly tap the affected keys to unstuck it, or put the laptop in a well-ventilated area if liquid was spilled to let it dry.
Apr 02, 2014 | Samsung Silver 13.3" Ultrabook...
Tip
How to Fix Touchpad on a Laptop
<p><span>The touchpad of your laptop is a most important and frequently used input device. If your touchpad stops functioning, it may be difficult for you to use your laptop. Touchpad normally faces following issues. <br /><br /><b>Laptop Problems and Their Solutions</b><br /><br /><b>Problems with the driver</b><br /><br />Computer hardware communicates with your computer through real time software called driver. Drivers control computer hardware. It is possible that virus or human activity may damage the driver. You can check your driver's status through computer's device manager. You'll see a yellow color indication under "Mouse and other pointing devices" heading. You can download new driver form your laptop's manufacturer website. <br /><br /><b>Problems with connection</b><br /><br />Touchpad's connection with motherboard is delicate. It can be broken due to heating and other inner problems. So, if there is no problem with the driver, then the connection of the touchpad to the motherboard may have broken. <br /><br /><b>Misuse</b><br /><br />Touchpad of the laptop is the most delicate input device. Some people tap on it too hard or use a shrill tool as an alternative of a finger. This can damage the pad. <br /><br /><b>Fn Keys</b><br /><br />Touchpad driver is slightly different from the other devices that need drivers to function properly. It came with an operating system that you don't need to re-install it. Laptop keyboard comes with many functions than the common keyboard. It has Fn keys which are called function keys. Sometimes, your laptop's touchpad stops working because you accidentally hit some one of the Fn keys. You can follow these instructions to make your laptop touchpad working again. <br /><br />1- Search for Fn key on your laptop keyboard. It is commonly located next to the Ctrl key. <br />2- Now search for F1 to F12 keys on the laptop keyboard. These keys control sound, brightness of the screen, wifi etc. They are located on top of the keyboard. Look for the key which has icon on it that looks similar to the touchpad. <br />3- Let's take an example of Toshiba laptop. It uses F10 key to enable or disable touch-pad. Hold down Fn key along with F10 key to enable the laptop touch-pad. <br /><br /><b>Cleaning the laptop touch-pad</b><br /><br />It is a good practice to clean your laptop touchpad. To clean it, take a cloth dampened with sprit. Wipe your touchpad off with that cloth. <br />Laptop touchpad work best in moderate temperature and gasping environment. Moisture, excessive heat, can damage it. Try using your laptop with tidy hands. Sweaty and dirty hands can cause problems. <br /><br /></span><span><span> </span></span><br /><span><br /> </span>
on Jan 06, 2011 | Computers & Internet
How to enable function keys on acer aspire 5349
Do a system restore before this happened might work, hook external keyboard to the laptop if no change, if external works, there is a problem with the laptop keyboard or bad device driver.
Mar 21, 2012 | Acer Aspire Computers & Internet
My hp laptop touch mouse pad has stop working
Ensure that you have not accidently disabled it check your function keys for a picture of a mouse with a line through it then hold the function key and that button at the same time.
Sep 04, 2011 | Computers & Internet
Mouse pad stopped working
If you are referring to the "touch pad" on Laptop/notebook, if the touchpad on your laptop is not working and is unresponsive, it's not broken, you or someone else has accidently deactivated it with the function key.
Then you can try this,
Most laptops (if not all) come with a function key. The function key is labelled "Fn" and usually stands out from the rest - either the "Fn" is in a different color or the key as a whole. The function key works in conjunction with other keys on the keyboard especially the ones in the top row marked "F1" to "F12". The combination of function key with these keys lets you perform various tasks quickly such as shutting the screen, putting the computer in sleep mode, switching the wireless connection on and off etc.
By keeping the function key pressed and then hitting one of the keys ("F1" to "F12"), activates a task. You can activate and deactivate the touchpad by using the function key with the "F8" key.
Hope it helps.
Dec 11, 2010 | Computers & Internet
Touchpad has stopped working
Try pressing the Function key and F7. The function key is 2 keys to the left of the spacebar if you are having trouble finding it.
Jan 05, 2010 | Acer Aspire 5580 Notebook
Mouse stopped working
Look on your function keys, there will be touch pad icon.Press that function ke with Fn key on your key pad the mouse will start the work.
If unable please sendthe exact model no. of the machine.
Thanks.
Dec 25, 2009 | Acer Aspire One PC Notebook
Toshiba function key display problems
I suggest that you perform System Restore to restore the Desktop.
Jun 23, 2009 | Toshiba Satellite A15-S127 Notebook
Turn on wireless with function key hp laptop
Assuming this is the DV7 series laptop you picked when you posted there is a small wireless key above the keyboard(not embedded in the F keys) that shout be orange with the wireless picture displaying if it has been turned of.
press the key and wait about ten seconds and it should be fine.
If the key doen't turn blue then you may have a "real" problem, if it does you should be fine.
Chris
Jun 02, 2009 | HP Pavilion dv7-1132nr Notebook PC
Keyboard does not work
If there is a lock feature, its probably on it as a function key. (maybe the F1, F2, etc keys?) Function keys are usually a different color and need to be used while pressing the Fn/Function key (could be called something else, just look for something other than shift/ctrl/alt/windows key).
Feb 25, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Computers & Internet Logo
David Payne
David Payne
