-   Pushing it in worked for me too. Sucked not having it for 3 days. Thanks for the advice!!!
-   Guest
May 17, 2009
-   My phone's camera didn't work and I got really worried, it said start error. When i read Randymack123's solution and did it, it didn't work the first few times. Then i pushed down on all the edges just another time around the camera and flash and it worked right away! -   Guest
May 06, 2009
-   when I go to try to take a pic or video it says camera start error-   kc1984
May 04, 2009
-   When I go to start my LG Dare camera it says camera start error/-   Guest
Apr 26, 2009
-   try to take a picture and it say camera start up error
-   Guest
ok here is what i did. opened up the back. took out battery. pushed down(in) really camera lens/flash on back of phone and felt it move back into place. replace batter. turn on. next time i tried camera worked normal again.
wow i cant believe it, it actually fixed my camera too thanks everyone pushing down on the lense did work. i was so frustrated with it and now it works thanks again
Specifically, push down on the section that reads '3.2 MEGA PIXALS'; if that doesn't work, take the 6 screws off thet back and push the flash module back in place. It's the little yellowish clear fresnel lens next to the camera lens. It will snap back into place. It's mis-aligned like a fat kid on a teeter totter.
I had the same problem, camera start error. Did a soft reset and all seemed fine. Called Verizon support to see if this would indeed fix it and was told to take it to a Verizon store to have it checked out just to make sure. Took it and it needed the camera software upgraded. Took about 45 minutes, so I left the phone and went shopping. Do this before your warranty expires.
bt studio 3100 base phone keeps flashing base1 i have put new batteries in please help the other...
(More)
bt studio 3100 base phone keeps flashing base1 i have put new batteries in please help the other phone is fine
Have a DS 1000 Nec. Want completly different ring tones for incoming calls. never know which line is...
(More)
Have a DS 1000 Nec. Want completly different ring tones for incoming calls. never know which line is ringing? The speaker phone and volume is horrific. Is there a way to boost this?
i dont understand what he said can someone pleaz explain it better if you know what his talking about pleaz!!!!! i really need to fix me phone!
Comment by Guest, posted on Mar 18, 2009
OH MY GOD!!!!!!!!!!! Thank you Randy sooooo much! i thought i was going to have to pay to replace my phone, i wouldve done it too and wasted my money if it wasnt for you advice...thanks again
