Question about Acer AL1715 17" LCD Monitor
Auto Config???? I have just recieved an acer monitor as a gift and I am having trouble with the auto configuration. a little box flashes through my screen all the time that says auto config please wait. How do I stop that from happening? I have tried to access the menu to change the setting of the auto config but nothing has worked so far. Please help....
  • 2 more comments
  • martihelp Dec 17, 2007
    i have the same issues as him and i already check the resolution and its at 1280-1024 and refresh rate is at 60hertz what else could i do
  • kallayanamit Jul 12, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to indiangirl's Auto Config???? problem, and notify you when a new solution is offered.
  • henry_kumar Sep 10, 2008
  • kjtwins2 Apr 12, 2009
    l have the same problem, cannot get rid of auto config. please wait box
    Acer AL
    Problem Solver:
  • 8 Answers
Auto Config should (in theory) reposition the viewing area of the screen dependant on the resolution. So it fires up when the resolution your monitor is working at is different than the native one (1280x1024), if it's working in windows - set the resolution to 1280x1024 and it should work ok. right click on desktop>properties>settings p.s. also set the refresh rate to 60 hertz.
Posted on Oct 24, 2006
Had the same problem, and found a pretty ghetto workaround.
Found that when I held in the power button, the box went away. So after trying tape and a couple other things, I just pushed the button in and jammed the end of a bent-out paperclip into the space between the button and the case.
Seems to be working, maybe someone else can figure out what the root of the problem is.
Posted on Nov 21, 2010
Mine is the same it always does that
Posted on Oct 22, 2009
    Problem Solver:
  • 5 Answers
Well i also have had this problem in the past and no matter what i did with the refresh rate and or resolution nothing would work. so i looked further and i tryed unpluging the unit and letting it sit that did not work and then i accidentaly hit the top of the monitor case rather hard ( I was mad and i punched it strieght down) and low and behold the auto config screen stoped comeing up. this lasted for a while until my computer desk was bumped and it started happeneing again. from what i can tell either the circut board is cracked where the buttons are or some how the case got twisted and is now putting preshure on the button like you are hitting it. so i carefully put presure on the case in the differnet direction while it was on to see if i could duplicate the problem and it started happeneding with when i put persure on the case in a certain way so i put preusre on it in the opposit direction and it stoped. when i take the case apart and look to see if it is the board or not i will post here again with my information . i hope this helps someone because i know how this problem can drive you nutz
Posted on Sep 22, 2009
SOURCE:
My Acer LCD Monitor shows the , auto Configuration menu and is on a black screen.
How did the auto configuration came about? Try pressing the buttons before powering up. Maybe some of it are stuck.
Feb 21, 2015 | Acer AL1916W 19" LCD Monitor
I have an acer AL1912 and a (auto config please wait) gray box keeps popping up,how do i stop it
If it gives you message about the resolution, set the computer to use native resolution of the monitor. You can change the resolution by right clicking on desktop and choosing "screen resolution".
Dec 27, 2013 | Acer AL1912 19" LCD Monitor
Mijn beeldscherm blijft steeds auto config
Elke monitor heeft een menu-optie. Zoek met uw handleiding hoe u uw menu-opties voor uw specifieke model en daar toegang te krijgen is een optie om berichten of waarschuwingen weer te geven. U **** het uit daar.
Jun 20, 2012 | Acer LCD Monitor P193W
A MESSAGE KEEPS POPPING UP ON MY SCREEN AUTO CONFIG HOW DO I STOP IT
Think I fixed it.. My monitor kept flashing autoconfig and shaking a little, so I went to control panel - clicked on system - clicked Hardware - clicked on device manager - clicked display adapters - and updated the driver. Re-booted computer..
So far so good... Fingers Crossed..
Oct 23, 2009 | Acer Computers & Internet
Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Jun 11, 2009 | Acer X193W LCD Monitor
Auto Config Please Wait message
Each monitor has a menu option. Find out with your manual how to access your menu options for your specific model and in there is an option to display messages or warnings. You can turn it off there.
Dec 01, 2008 | Acer Computers & Internet
Processing auto configuration
Check your settings in "Power Options Properties".
Control panel/ power options/ advanced/ under power buttons make sure you have "shut down" when you press the power button on your computer.
I hope I am understanding your problem correctly. If not pls. explain what you mean by and when processing auto config. keeps flashing. Is there a black screen or a windows interface?
Nov 18, 2008 | Acer AL1711 17" LCD Monitor
Acer AL1912 Monitor
ditto here, hopefully someone will have a solution
Oct 20, 2007 | Computers & Internet
Acer auto config
same here never buy a freaking acer
Aug 24, 2007 | Acer AL1715 17" LCD Monitor
Acer AL1715 17" LCD Monitor Logo
3,133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
