Question about Philips GoGear SA5285/37 Digital Media Player
It won't turn on! Please help asap!
My GoGear SA5285/37 8GB won't turn on all of a sudden! Why is that? And most importantly, what can I do to get it back on? I've tried holding 'vol +' and 'power' buttons together, but don't get anything. Also tried the reset small button close by the cable port.
Please, help!!
Thank you!!
  • kingofmusic Dec 29, 2008
    i have the samp problem
  • 8,596 Answers
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 18, 2009
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
Tv won't turn on!
Your problem post has not enough details to post a solution. Check this site named 'Electro-help'. so many faults to plasma TVs are there. Check it. Click this link, and select the site named above.
Jul 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
I have imported music onto it Now I can not figure out how to turn it on. The picture instruction booklet is of no help to me
Hi wardjea...
You can go to the following website and download a user manual for this gogear vibe.
It will be easier to use
Please take time to rate me
Aug 30, 2011 | Philips GoGear ViBE Digital Media Player
I need help puttin videos on my philiips gogear
hi, mp3 phillips gogear work only , if you have window media 11 happy to help yvon chow !!!
Jan 03, 2009 | Philips GOGEAR SA6045 MP3 Player
My philips gogear wont turn on
Disconnect the GoGear from the computer
Reset it first (pinhole in back - safety pins work best), even if nothing happens - just to be on the safe side
Nothing will happen still, but we are OK
Make sure the power is off, and hold in the volume + button, reconnect the GoGear to the computer while holding in the volume + button, and continue holding volume + until a window pops us saying Found New Hardware Wizard
Go through the Found New Hardware Wizard, and the GoGear should be working again - the player will be revived
Write me back if this fails to resolve the problem.
-Tha Mp3 Doctor
Jun 17, 2008 | Philips GoGear HDD6330 MP3 Player
Philips gogear sa261 doesn't switch on...
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 24, 2008 | Philips GoGear SA261 MP3 Player
INSTALLTION
Download software and drivers from www.p4c.philips.com
Select language and country
Put the model number in the search box SA6045/xx (where xx is the country code on the back label)
Select Software & Downloads.
Select relevant files to download.
Feb 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Froze on the screen
Here's what you want to do:
1) Back up all music and picture files if possible
2) With the GoGear powered on, reset the player by holding the power on/off and volume + keys simultaneously until the GoGear shuts down
3) Turn the GoGear back on and see if message persists
If the "please connect player to PC" msg persists:
1) Connect GoGear to computer
2) Open Philips Device Manager (Start --> All Programs --> Philips in Windows XP if no shortcut on desktop)
3) Click on the Repair tab - see if there is a msg that says something like "to repair your player, connect GoGear to computer while holding the volume + button"
4)IMPORTANT: Disconnect the GoGear from the USB cable, turn the GoGear OFF, and then press and hold the volume + button; then, connect your GoGear to PC while still holding the volume + button (VERY IMPORTANT: this process will fix your player, but it will also delete all music and images you have stored on the GoGear) - do not let go of the Volume + button until a pop-up comes up saying that your player is being repaired
After the repair process is complete, your player should work fine - you will have to re-download all files to the GoGear.
-ThaMp3Doctor
Feb 04, 2008 | Philips HDD1630 MP3 Player
Cant download songs
Go to www.usasupport.philips.com , enter in your GoGear model number, click on the exact model number, and then click on the software and drivers tab; there will be the latest version of the "Device/Firmware Manager" on the website.
-Tha Mp3 Doctor
Dec 31, 2007 | Philips GoGear SA178 MP3 Player
Philips HDD 1630 won't charge
I have the same problem I think that the internal battery died... is it possible to change it?
May 22, 2007 | Philips HDD1630 MP3 Player
Philips GoGear SA5285/37  Digital Media Player Logo
114 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
