Question about Lexmark Office Equipment & Supplies
I am having problems connecting to a lexmark 4800 printer using wifi on one laptop. it only works through usb. uninstalling and re-installing drivers/software has no success. printer works fine on other laptop/pc which makes me think the problem lies with this laptop?
  • mlsmjs Nov 09, 2008
    Thanks, it was a firewall problem. you are a star!!
    Genius:
  • 1,913 Answers
Check your windoes firewall and antivirus firewall .
also check ping to your network printer.
try to ping those ip if u get ping then it is ok.
check your printer and laptop gate way is same.
run this command in "run" iss "ping 192.168.15.1" ehchange your printer ip in this command.
thats it.
Posted on Nov 09, 2008
I have lexmrk x5650 and cannot get it to work with my macpro laptop.it will only work if I directly connect printer cable to laptop. It will not work wirelessly. Had no problem with my other windows...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Feb 29, 2012 | Lexmark X5650 AllInOne InkJet Printer
Lexmark X4550 Scanner not working
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Why won't my printer scan a document to my laptop?
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
Why isn't it scanning a document to my laptop
I had same problem, even if I download de cjb3500_4500en the processo goes on but when I put to configure wifi (orange) they ask me to put a usb cable, but on actives the button do continue if the USB was...
You did a nice job trying out other ways to install the printer successfully. However, it's weird that 3 computers are not recognizing the USB connection. Make sure that the USB cable is plugged in correctly (in the right position) in the USB port of the printer.
Next, use the correct driver that is compatible with your computer's operating system. You may need to uninstall the existing software before reinstalling the new one. Instructions on how to uninstall the Lexmark software available at http://bit.ly/8ZH59T. Then, you can download the drivers at:
If problem continues, contact Lexmark technical support.
Oct 10, 2010 | Lexmark X4550 InkJet Printer
My printer is not printing Lexmark 5400 series
DO NOT use the Windows 7 Lexmark Driver for the 5400 series on the model X5470 all-in-one! I just assembled a new Win 7 computer and could not get the obvious Win7 64 bit driver to work. I called Lexmark tech support several times, and the third time they conceded that you can't use it. You have to use THIS ONE!
CJS5400en.exe (just for the X5400). Make sure you UNINSTALL COMPLETELY any previous Lexmark printer driver and check the hard drive for any vestiges of previous installations BEFORE installing the new driver...and do NOT use the 'cleaning utility' file that is on the Lexmark site for Win 7 - to clean all bits of former installations first...According to tech support, it doesn't work on Win 7!! I told the tech person that the driver site needs to be more specific on which models use which drivers...he agreed.
Feb 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark z1480 wifi configuration
is the printer installed without USB cable?
if not, then you need to reinstall the application without the usb cable connected.
Ping the printer IP address after you have setup the printer.
Jan 05, 2009 | Office Equipment & Supplies
Lexmark 1290 on Vista Printing Blank Pages
Fond this on the Lexmark Website. Hope it helps.
Attention Windows Vista Users
If you have installed your printer on your PC using an original Lexmark Driver CD that came with your product and you are experiencing problems when printing, you may have installed the Windows XP driver.
Follow these steps to resolve:
· 1) Disconnect your USB cable from your printer.
· 2) Uninstall all Lexmark printer drivers on your PC.
· 3) Download the correct Vista driver for your model.
· 4) While leaving the USB unconnected, Install the driver on your PC.
Important - Do not reconnect the USB cable until the install software prompts the question of how the printer is connected.
Oct 31, 2008 | Lexmark X1290 All-In-One InkJet Printer
Lexmark P6350 and New Imac intel compatibility
I'm part way there.  I rang Lexmark and they say P6350 can only work with Mac OS up to 10.4 whereas I'm using 10.5.2.  I'm not yet fully convinced it can't be made to work and a knowledgeable friend will be round later.  I may get back to you. Porphyry
Feb 22, 2008 | Lexmark P6350 All-In-One InkJet Printer
Printer problem lexmark and hewlett packard
Turn off all your security software (antivirus, firewalls), download the latest drivers from the lexmark site, manually extract them to a folder without running the setup wizard- connect printer to usb- go to the folder you extracted the files to, right click on the setup file and 'run as administrator'- it should successfully install and go wireless-
Jan 02, 2008 | Office Equipment & Supplies
137 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
