Question about Dell E171FPb 17" Flat Panel LCD Monitor
Strange problem Ok i havem my Dell 17" TFT, but the problem is one day i left it on connected to my 360 and when i came back, no longer than 20 minutes, there where millions white lines everywhere going horizontally acroos the whole screen of varying thickness, and the rest of the background was un readable but you can still see some movement if you look carefully. i know its nothing wrong with the cable because i took it out and the no signal box turned into a gray vertical rectangle which movede a little bit every three seconds. i remeber this happening a few months ago but i think it fixed itself. any help would be great appreciated! thnx in advance
  • tris edwards Oct 25, 2006
    You can also see the colours, but they are all in vertical bands, heres a picture of it when i was watching a dvd:
  • William Conklin May 18, 2008
    I have the same problem as trissy with the Dell E171fpb. Horizontal and vertical lines, you said it is the circuit, can this be replaced? and if so where can I get it.? pop
    Genius:
  • 1,554 Answers
Unplug the monitor from the vga , does the osd test come up ,
if not then the circuit is the issue,
if it does then you may have the refresh set too high.
Posted on Apr 25, 2008
How un lock osd manu dell lcd 1704 fpv
Press the menu button and keep pressed for 20 seconds or untill OSD unlocked message come and same procedure for OSD lock.
Thanks,
Bhautesh
Aug 20, 2010 | Dell 1704FPVs 17" TFT LCD Flat Panel...
The monitor went dark, seems to have no power.
Totally darken the room your computer is in, and see if you can see a very-dim image on your computer.
If so, it could be the "inverter" part inside the LCD that has failed (about a $20 part, but will take a technician about $50 to $75 to disassemble/replace/reassemble/test).
Try connecting the monitor to a different computer, to see if the monitor is OK.
Try connecting a different monitor to your computer, to see if the video-card is OK.
Jun 23, 2010 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Dell monitor 1703FPs
you backlights are going off.y ou need to replace the power supply in this monitor very comon problem
Dec 30, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
The Dell E17Fpf 17" TFT LCD Monitor power-on very dark with the left side of the screen darker than the right. After on for about a minute, the brightness comes up to near normal brightness. Please...
Your backlight inverter is about to go out. There are 2 small parts that need to be replaced. Check our web site at: www.ccl-la.com, we have a step by step repair guide to that model.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 21, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Blurred "No Signal" in the TFT when only power cable is connected.
in display settings try to reset the screen resolution
Oct 16, 2008 | Acer AL2216W LCD Monitor
Dell 1703 FPi 17" TFT LCD Flat Panel
First there is a seprate snap frame around screen itself, there about four location on snap frame , 2 on each side ,use flat screw driver to seperate frame, there in slots like,there might be 2 on the top also,then go for screws in back, remove button panel from front side and remove flat wire connections to the board ,they pull out of slot on board , be careful putting them back in ,take your time they will go back in by pushing on the stiff part,about a 1/8 or so from the end to go in. of the connection,go for the VGA connection ,you will remve screws to seperate screen it self to get to the connection, it just pulls out of the socket on the board,hope this helps
Sep 08, 2007 | Dell UltraSharp 1703FP Flat panel TFT 17"...
you have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Sep 06, 2007 | Dell 1703FPt 17" TFT LCD Flat Panel...
Dell E171FPb 17" Flat Panel LCD Monitor Logo
100 people viewed this question
Alun Cox
