My naim audio cd3.5 player has developed a fault, whereby when you load a cd in, it dosent always start spinning and dosent always play - you have to keep opening and shutting the cd tray until it starts! It also then makes a periodic noise whilst playing.
  • 4234 Answers
SOURCE: I have a sa-gx770 techniques
There are bad solder connections inside the receiver that are causing the protection circuit to kick in. This is a simple resoldering job and should only cost the labor rate at a local service shop.
Dan
Posted on Jun 02, 2008
  • 18 Answers
SOURCE: Cd player spins and then shuts off.
it could be that the lens needs to be cleaned. best soltion is to go to an elctronic store and ask them for a lens cleaner it should be very cheap if that doesnt solve your problem then ill try to find another solution
Posted on Jan 09, 2009
lynchms
  • 93 Answers
SOURCE: CD player fails to read
This is a typical problem when the laser " eye" gets dust on it, unplug the unit and you can try to remove cover and spray the optical pickup "eye' with canned compressed air or other type of optical cleaner found at say like radio shacks, I have solved many disc reading errors with this method
Posted on Jan 26, 2009
rulds2008
  • 3866 Answers
SOURCE: one day i was playing halo 3 and my disk drive
This hard disk is a easy fix, You can buy a new one for the fraction of the cost, All you have to do is slip this off the unit and apply an new or even a used hard drive. Here is some links for some hard drives http://catalog.ebay.com/Microsoft-Hard-Drive-120-GB-9Z600001-for-Xbox-360_W0QQ_fifptsZ1QQ_pcatidZ413QQ_pidZ70884347QQ_trksidZp3286Q2ec0Q2em271
you can get some for under 30 bucks. if this information helps please rate accordenly Thanks
Posted on May 02, 2009
  • 4234 Answers
SOURCE: DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
Posted on May 30, 2009
Rega planner 3
If the amp does not have a dedicated sockets for a turntable - often marked "phono". Then plugging it into an aux socket won't work. You will need to get a Magnetic Cartridge Pre-amp. The turntable plugs into this and that plugs into your aux socket. If at the present you turn up the volume really loud you might just hear the record playing. That will tell you that the cartridge is OK.
Jul 14, 2013 | Audio Players & Recorders
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
Cd wont play it picks up an goes around but wont play need to know what to do
It sounds that the optical pickup unit to your player is faulty. Open the top cover of the player, power it ON and insert a CD in to. Check whether the inserted CD loads well into the mechanism and spins. If do not spins, sled motor is faulty. If it spins, optical pickup unit should be replaced.
Apr 23, 2012 | Durabrand CD2160 Shelf System
My CD player keeps displaying no disk and wont play the cleaner disc, is something dirty or broken?
Hello
If it does not play the cleaner disc, just inspect whether the disc inserted in spins inside it. You can check this by open the upper cover of the player, and inserting a disc into it. If inserted disc spins inside, and the player won't read it, the fault is with its laser pickup unit, and it should be replaced with same type and number.
If the disc dos not spins, the fault is with the sled motor [the motor that spins the inserted disc], has damaged, and should be replaced. OK.
Dec 25, 2011 | Sharp Audio Players & Recorders
Hswf 147 hoover washing machine wont spin
Not spinning at all can sometimes be caused by a blocked filter or drain pipe. Does your machine spin if you turn the dial to the spin only setting? Ours has developed a fault whereby it won't spin at the end of a normal cycle, but if I turn the dial to 'off' then to 'spin only', it will spin.
Dec 11, 2010 | Hoover Washing Machines
My technics sl-p770 doesn?t recognize the loaded CD.A cd is alway spin but not any track in audio cd.
Try cleaning the lens with a cd/dvd lens cleaner disc. Another thing of note....some cd players simply will not recognize homemade cds, or dics that are not audio discs, or if they were made on a computer.
Apr 15, 2010 | Technics SL-PS770D CD Player
Have a Jensen Audio CD-472 portable AM/FM Stereo CD player that won't play my Memorex CD's that I compiled with songs in MP3 format. Can you tell me why this has happened? The commercial CDs I have in my...
I know that some players were not designed to recognise some formats of CD, often those created by computer drives. But if it did play them it must have developed a fault in the electronics part that recognises CD formats. Hence it's problem now. Without a service manual perhaps a tricky thing to put right.
Jan 06, 2010 | Audio Players & Recorders
Alpine CDE0-7826P Cd Player doesn't always work
If It dosent play burned cds its not an mp3 compatiable cd player as far as the other problem kinda seems like its time for a new cd player
Jun 14, 2009 | Alpine CDE-7826P
I have a Denon DVD-1920 DVD/CD player that is less than 18 months old. It has developed a problem whereby it refuses to play any DVD through to completion. It will play for a short period of time and then...
Yes, the unit must be opened to access the lens. Open up the top and you should be able to get at the optical assembly. Clean the lens using a cotton swab and alcohol. Try a DVD. If the problem persists, try playing a music CD. If the music CD plays but the DVD does not, the optics are starting to fail and should be replaced.
Dan
May 07, 2008 | Televison & Video
Cd function not working
you can always try cleaning the lense and if that dosent work exchange it for a new one
Feb 01, 2008 | Jwin JX-CD780 Personal CD Player
207 people viewed this question
 Grubhead
Grubhead
