Question about Brady TLS 2200 Label Printer
Errors my printer is showing some error like code sum 60d6d0
  • 4 Answers
I believe this is a checksum error. Most likely the CMOS Button Cell Battery is dead and CMOS
memory is now corrupt !.
Replace the CMOS Battery if less then 3.6V. It is located under the Main Battery.
Then reload the latest software !
Hope this solves your problem
Posted on Dec 05, 2008
  • richtrash Jun 27, 2011
    Does anyone know what voltage the CMOS Battery is, the one I have in is a CR2303 which obviously isn't the correct battery.
    If someone could see if there are any part numbers on the battery installed it would be appreciated.
HELP! I had this error CODESUM:8605DE !MEMORY ERROR! on my Brady TLS2200 after disconnecting the board due to broken lock lever. the CMOS batt is only 3.1V. Is this the same roblem as above? How do we reload the latest software?
Posted on Nov 15, 2009
My printer hiti s420 writes check sum error sdram and show code 197378
Your printer would need a reset and/or repair
hope all electrical outlets and other devices connected to the HiTi are grounded well and you eliminate any static discharge when using the printer.
Mar 31, 2016 | HiTi S420 Photo Printer
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
Feb 27, 2015 | Sharp Office Equipment & Supplies
What are the error codes on my printer,5010 & 6100?
The 5010 error indicates a scanner error. The scanner unit cannot detect the home position, or the scanner unit warming-up is not done properly at power-on. On the LCD, "Scanner is not operating correctly." is displayed.
The 6100 error indicates a logic board error. The check sum value is incorrect in the ROM check at hard-power-on.
Fixing these errors is more expensive than replacing the printer. Sorry.
Fixing F
Feb 05, 2015 | Canon PIXMA MP830 All-In-One InkJet...
That service code refers to the flash dimm, which is on the main pwb assy (controller). You have to try upgrading the system firmware. If the upgrade procedure fails, then you have to replace the flash dimm.
Jul 25, 2014 | Kyocera Mita Office Equipment & Supplies
Oven doesn't work. Panel shows "FFF"
FFF code - Control error, failed EEPROM
The main control operates a series of software commands, which control the various features and functions of the oven. Each function or operation has a numerical value assigned to it. The numerical values can be added up - this is called the check sum operation. Every time the system is powered up and after each clean cycle the system performs a check sum and compares the value to the value programmed into the software (stored in memory).
An EEPROM check sum error or FFF code occurs when the values differ. If this happens, replace the oven control board (also called clock or ERC).
Replace the oven control board (also called clock or ERC).
Hope this helps.
Jun 27, 2011 | Kitchen Ranges
U2-40 error on sharp AR-M207 displayed on the digital display... what do i do
U2 04 EEPROM serial communication error
11 Counter check sum error
12 Adjustment value check sum error (EEPROM)
40 CRUM communication error
this the U2 Code Error
Jun 09, 2010 | Sharp AR-M207 All-In-One Laser Printer
1.EEPROM read/write error (serial communication error)
2.counter check sum error (EEPROM)
3.adjustment value check sum error (EEPROM)
4.CRUM chip communication error
Apr 30, 2010 | Sharp AR-M280N Copier
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
My sharp ar150n shows u2 error code and wont work please help
U2 is a problem in the laser unit, if after resetting it is still showing then you need to get it replaced.
Nov 30, 2009 | Sharp Office Equipment & Supplies
Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
Brady TLS 2200 Label Printer Logo
693 people viewed this question
Top Brady Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Bob Rambo
Level 1 Expert
Are you a Brady Office Equipment and Supply Expert? Answer questions, earn points and help others
