Question about Samsung Refrigerators
Samsung Side by Side Refrigerator
My regriferator has stopped working. The lights inside and on the panel still work but it does not run. Does that mean there is a problem with my compressor? If so, how do I repair it?
Thank you,
Jason
    Genius:
  • 1,122 Answers
If the fan in the freezer is running and there is no frost buildup yes a would think it's the comp.can you pull it out to see if it is running at all,if not the first thing you can do is get a 3in1 starter from your local appliance parts store($10) if it still does not start it narrows it down to the thermostat or drodt timer,let me know how you do-mike
Posted on Nov 09, 2008
How does ptc overload relay work on samsung RS2360sh?
If you can find it watch this video
https://www.youtube.com/watch?v=ZTKpYdFKPFE
Aug 27, 2014 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator and freezer not working
What is the model number for you fridge?
Mar 12, 2013 | Refrigerators
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Stopped working
I had the problem with a totally different refrigerator but it was the fuse on the printed circuit panel mounted in the back of the refrig.
Nov 20, 2011 | LG LSC27910 (265 cu ft) Side by Side...
Hi ! my 3 years old fridge Samsung Rs2630ww
lashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.
Mar 24, 2011 | Samsung RS2630WW Side by Side Refrigerator
My samsung refrigerator is 4 and 1/2 years old, the fan started making noise and the inside walls of the regrigerator and freezer were hot. one night it stopped working and there is no activity on the...
replace the compressor fan when it stops working the lines heat up also unplug your unit if it keeps running without the fan you will do damage to your compressor i suppose if you had no wear else to keep your food you would use a large portable fan to blow on the compressor bulb this is not a permanent fix and may only work till you get the new fan if you have any further questions message me back and please rememeber to rank how this opinion has helped thanks Rick
Jan 29, 2011 | Samsung Refrigerators
I defrosted the freezer and now there is a light blinking on the front panel. what do I need to do to get it running again
probably change filter and cancel light . instructions for your model . holding 2 buttons on control for 3 sec should stop light. finding the correct ons is the trick .. there may be info on or in the ref . a tec sheet is sometimes behind the grill at the toe . whirl / maytag / ect . some models of maytag are samsungs . if some of these don't work get back with me . we'll look a little harder ..mm
Dec 12, 2009 | Samsung RS2630WW Side by Side Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Oct 30, 2008 | Samsung RS2630SH Side by Side Refrigerator
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Dec 22, 2007 | Samsung RS2534 Side by Side Refrigerator
Not working 3 weeks after it's shipped
the unit is under warranty contact the dealer and set up a service call free of charge
Sep 10, 2007 | Jenn-Air JCD2297KE Side by Side...
Refrigerators Logo
47 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
