Question about Energizer Rechargable Battery with Charger
I have a car jump starter unit that was left and went dead flat. Now it will not take a charge pluging in the charger?
    Problem Solver:
  • 8 Answers
Unfortunately, a Jump Starting Unit which no longer takes a charge usually means the internal batteries had gone bad. On some charging units, the replacement batteries are available through the manufacturer, but more times than not, it's less expensive to replace the Jump Starting Unit.
Posted on Mar 23, 2009
Why does my new motor trend power house jump starter with air compressor not take a charge from the a.c. or d.c. charger?
Contact manufacturer. If still under warranty they should replace. Sounds like the internal battery is dead...there has to be a little "juice" left in the battery for the charger to have a complete circuit to charge...some of these units take 24 or more hours on an initial charge.
Hope this helps,Ron
Nov 30, 2014 | Power Center Jumpstart 11-411
How do I set the settings on my NAPA automatic starter/charger 85-435 to charge my car battery or to try to quick start my car? I have a 1997 VW Cabriolet.
It is best to "trickle charge" a low/dead car battery using the lowest setting. The "jump start" function will probably not have enough juice to start your car by itself. Refer to the manual of your charger for safety precautions.
Oct 03, 2014 | Cars & Trucks
2004 Volvo XC70 won't unlock
Put a battery charger on the starter cable from
under the car & ground the black charger lead
That will charge it enough to open the door & hood
Thought every car has at least one key cylinder on
drivers door !!
Jul 08, 2013 | 2004 Volvo XC70
I have a duralast jump starter BP-DLG. i cannot get it charged. i have pluged it to a standard electrical outlet and now it is dead. i have used it in the past and it worked very well. i mis-laid my...
My Duralast Gold Jump Starter Model BP-DLG will not take a charge. When it is plugged into the charger it shows fully charged; when I unplug it it goes dead, will not start and the red light shows. I have used it about 4 times in less than two years.
Feb 20, 2011 | RoadPro Road Pro 12 Volt Dc Portable...
Car wont start, just a clicking noise from the engine, insurtument clocks go all the way round before resting back at zero
If you are getting a rapid clicking noise, that means the battery is dead or you have a poor connection between the battery and starter. It could also be a poor connection on the negative or ground side of the battery or ground cable. Try jump starting it or put a battery charger on it for a half hour or so and try it again. If you get it going you should have the charging system and battery checked ASAP (as soon as posible). If you don't need to go anywhere leave the charger on the battery over night, set the charger on a slow charge rate less than 15 amps.
Jan 03, 2010 | 2005 Chrysler Town & Country
My raptor 660 had a flat battery so i used jump leads and jumped it from my car, it started fine and i left it running for about 20 minutes and there was no problems but all of a suddeen it just went dead...
Check the fuses. Get a new battery and get a 2amp trickle charger and charge the battery for 6 hours. NEVER charge a bike battery with more than a two amp charger. Pray that the CDI ignition is not shot.
Jun 13, 2009 | 2004 Yamaha XT 660 R
Help!
key off and out,diconnect negitive side of battrey then postive.clean terimals,charge battrey,connect postive cable (with key off)connect negitive.and start.
your dead battrey is taking up a big load on system,so when you boost it the dead battrey is taking it all the starter is geeting vey little.thats the clicking.
if you dont have a charger dicconect both terminals the same way again,put the jumper cables on the dead battrey.let it charge battrey for 10 15 mins .the longer the better.remover jumpers.
with key off and out conected battrey terminals.connect jumper cables and start.
let me know if it start or not hopefully the key hasnt lost its coding.
Dec 04, 2008 | 2003 Volkswagen Golf
Dead unit
My Quest2 has a short in it that drains the battery even when it is turned off. But the battery lasts normal 15 to 20 hours when fully charged and unit is on. Whenever the battery is completely dead, I have to place it on the charger for a hour or two before the unit will even start even though it is plugged plugged in. The battery can be replaced by the staff at batteries plus for under $60.00
Oct 12, 2008 | Garmin Quest GPS Receiver
Wont start
it could be the starter sticking next time when it doesnt start try tapping the starter with a spanner.
Jul 25, 2008 | 1996 Chevrolet Cavalier
Wont charge new battery
maybe your new battery is messed up
Apr 07, 2008 | Apple iPod nano 3rd Generation
Energizer Rechargable Battery with Charger Logo
204 people viewed this question
Top Energizer Electronics - Others Experts
cwradio73
Are you an Energizer Electronics - Other Expert? Answer questions, earn points and help others
