Slj4899 sonykv32dx30u led flashes 5 times
Thank you for the advice, I would like to have a go at repairing it myself.
I have some basic electronics knowledge but have never fixed a TV before.
Any help you can give would be greatly appreciated.
  • 10,594 Answers
Please click My Reply on your previous post.
Posted on Nov 09, 2008
TV will not come on, white light center bottom of tv flashes twice then 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 26, 2015 | Sharp 70" LC-70LE757U AQUOS Full HD Smart...
Hi, if I change my computer to my Nissan 300ZX 1986 I have to reset my computer or simply change it. Thank you for answer.
There is no re-setting. You just change it out. Be sure and disconnect battery before unplugging the ecu. It's a simple swap and go.
If yours is like my '87 Sentra, there is no trouble code capability, but there are limited diagnostic functions. The red and green LED lights and the diagnostic switch (on/off), can tell you if problems are present in the system or not. You just have to follow the diagnostic procedure.
Here's how: Make sure diagnostic switch on ecu is off. Run engine at 2000 rpm for 5 minutes, at no load. Look at green led: if it flashes at least 5 times in 10 seconds (that is the oxygen sensor making it flash), turn car off. Turn diagnostic switch on. Turn key to on, do not start engine. Check led's: if red is off and green on steady-No problems present in system.
If the red light is on and green light is flashing, post back and I can furnish the rest of the diagnostic procedure-basically, you will be checking voltages and resistance of all solenoids and relays the ecu controls. The green led may flash in two different sequences (either longer flashes and short pauses, or longer pauses and short flashes) when in diag. mode (with the red led on), and that will lead you down two different diagnostic routes. Pretty simple, really, and pretty effective. Took me hours and hours before I realized I even had this diagnostic function.
Aug 18, 2013 | Nissan 300ZX Cars & Trucks
The tv is a model# WS48311 serial# 106199. The prob is the set turns on (green light) after 1-2 seconds it shuts off It is a Mitsubishi
Hi Sheldon,
First of all, thank you for posting your question here at Fixya.
The symptoms you've mentioned is an indication that the unit gone to malfunction. My first advice is to unplug the unit from the outlet(AC source) for at least 15 minutes to reset the system and then check if the symptoms remain the same. If yes, lets check the LED error code to determine where the fault came from by following the steps below.
Press and hold for 5 seconds the front panel button keys "Input" and "Menu" at the same time to activate the error code mode. The LED will flashes a two digit error code.
Example : if the error code is "22", the led will flash two times pause and then flash again two times and the error code will cycle for five times.
Please let me know the result to continue our diagnosis.
mjsazon
Jan 17, 2012 | Mitsubishi WS-55513 55" Rear Projection...
When i turn on the tv the led flashes 4 times and tv takes 4 minutes to come on and when it comes on the led flashes 5 times
Flashes of your led light indicates an error code. This is usually caused by leaky filter electrolytic capacitor. This will affect the regulation of the supply and sometimes needs a little warm-up to function normally. This faulty capacitor is in the regulator section/low voltage power supply. The symptom will get worst if not isolated.
This is not DIY. I've advice you to send it to repair shop or look for a qualified technician to fix the problem.
Hope it may help you!
Have a nice day.
JDVillanueva
Jan 31, 2011 | Televison & Video
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
Slj4899 KV32DX30u led flashes 5 times no picture
Please check 1000 volt at CN703 on C board fixed on picture tube.
Nov 10, 2008 | Televison & Video
Camera keeps on changing Modes: camera, network, camcorder w/o touching anything
Hello, i would not advice to repair the camcorder by yourself. It is better to be safe then sorry. If you need more info please advice. Arpi
Mar 12, 2007 | Sony Handycam DCR-IP220 Micro MV Digital...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
