Question about Magellan RoadMate 700 GPS Receiver
Temperature below safe level
My GPS Magellan Roadmate 700 has suddenly started taking 15 - 20 minutes to start. Once it starts everything is ok. It will give a message temperature below safe level. Please turn on the heater. ( not exact ) Magellan repair is $150 for which I can actually buy a used 700 from ebay with 1 year warranty. Can you please help me if I can fix this problem.
  • short55w Feb 24, 2008
    I get a white screen now. No back lights to the control buttons.
    What can I do?
  • al fong May 11, 2010
    what is required to do a hard drive swap? i found that swapping a hard drive will only work if you use the board its on with the new drive. otherwise it cannot find maps? would i have to back up the drive then copy the info to the new drive? what if the maps on the newer drive are a newer revision? can i keep them?
    Novelist:
    Scholar:
  • 86 Answers
I've fixed that error by swapping out the PCB board (or the keypad board). Which you can't very easily do that.. unless of course you have a boneyard of these lying around. Additionally, it could be the Hard Drive, this error hasn't been narrowed down to any one specific cause to my knowledge. I'll take it off your hands if your going to buy another one though. Respectfully, -Dan
Posted on Oct 24, 2006
SOURCE:
When i power up my roadmate 700 a message comes up that saysTemperature below safe level. mTake several minutes to warm up. but nothing happens even when its warm
Had the same problem with my MRM 700 back in 2005, only 2 months after I purchased it. They changed the connector, and it worked. BUT, few months later I had the same problem again. I haven't used it anymore since then (moved to another country), now I am trying to fix it but no warranty anymore..
Jan 28, 2010 | Magellan RoadMate 700 GPS Receiver
My Mgellan 700 was working fine for many years.
ok56,
Thanks for using Fixya 1st of all.
This problem has surfaced MANY times. It has been solved by numerous solutions. Without replacing the circuit board behind the keypad or the LCD I do NOT know a way to solve this. There never was a definite solution that remedies this. Possibly unplugging/replugging the ribbon cable from the LCD. Sorry I couldn't be of more assistance. Let me know if anything changes.
-Daniel
Nov 15, 2008 | Magellan RoadMate 700 GPS Receiver
I had a Roadmate 700 with the same problem as yours, and the solution was simple: the hard drive inside had come loose!
All I did was open up the unit (4 screws on the back and a small snap-together clip on the end), and plugged the hard drive back into the cable. The cable has 2 black posts that fit into the hard drive, so you can't misalign the pins. On mine, the hard drive label was facing UP.
Once the hard drive was plugged in, I powered up, and could hear the hard drive spin up (which I hadn't heard before). The unit booted from the "Magellan" screen right into the menu almost immediately!
Hope this helps someone!!
May 23, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700 "powerup problem"
Apr 01, 2008 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
Downloading new version 6 to my roadmate 700-760 gps
I had a very similar problem downloading the new version for my roadmate 700 as well. I chose to shut system down .I then unplugged everything. I reinstalled the dvd into my computer.I powered up the roadmate700 and hit the enter button and the screen came up to pick user I hit user one. I plugged the USB calble in and started the download again and it worked out for me just fine. I hope this works for you also. Good Luck
Dec 21, 2007 | Magellan RoadMate 700 GPS Receiver
System works erratically
This can happen, as you probably know, when driving in areas of tall buildings - I have an extension aerial that sits on rthe car roof.
BUT BUT BUT.. these Magellan units are so poor compared to Tomtom and Magellan Support is RUBBISH!!!!!
I am at last binning my Roadmate 700 and am getting a Tomtom Go series which auto updates every time it's put on its cradle attached to my PC/internet.
Oct 20, 2007 | Magellan RoadMate 700 GPS Receiver
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
Temperature below safe level warning when starting GPS
Ahh yes the ever so elusive temp. below safe level error. lol. (sorry) Attached to the radio board are 3 wires connecting to the top of your lcd. This is where the temp is read from. I know telling you this doesn't help, just info. This problem has been fixed from swapping out radio boards (the board that's behind your keypad), additionally swapping out hard drives. I'm not sure if the unit will detect the USB but, if you can, try re-loading whichever version you have ie. 4.32/5.14. As far as end user fixes, I don't exactly have one unless you can find a scrap unit that someone doesn't want b/c it's malfunctioned as well. Good luck and I wish I could of been more help. -Dan
Sep 24, 2006 | Magellan RoadMate 700 GPS Receiver
RoadMate 700 GPS is not working..
Does the initial Magellan screen appear? If it doesn't display anything and it's just blue... :( Normally means that something on the main board is your problem. Which, means your out of luck. What happened to it? It just suddenly stopped working? Let me know. R/
Sep 17, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
100 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Damen Wong
Damen Wong
Are you a Magellan GPS Expert? Answer questions, earn points and help others
