Question about KDS Valiant 6481C (KN6481CIPT-02) PC Notebook
Valiant 6481CPTD My battery will not charge, so I am going to get a new one, but I also have a problem using the laptop keyboard. I cannot get the symbol lock to turn off. I am not sure it has anything to do with the battery. I can plug the laptop in directly without the battery, but can't do much else because the symbol lock is on. When I attach a external keyboad it works fine. Any help would be appreciated. Thanks Richard Anderson Andycap
  • 24 Answers
Go to ths link and search for your model of laptop they may have a keyboard for it. www.laptopparts.com
Posted on Mar 29, 2007
Where is the "tm" symbol
There is no "tm" symbol key on a keyboard, you need to enter an ALT key to type the trademark symbol.
Hold down the "ALT" key while typing 0153 and it will enter this: ™ when you release the ALT key
Mar 04, 2011 | ASUS Eee 4G Notebook
Hai there.... yesterday i bought new battery for my acer aspire 4520. Why the orange light keep blinking when the battery were charge???als0 there is no show the charge symbol on my screen??? I really...
when orange light is on it means it is charging and to know whether your system is charging just look at battery symbol where you will find a wire symbol on battery which show it is charging and when charge is complete orange light turns blue
Feb 15, 2011 | Acer Aspire One PC Notebook
When I try to use my numbers at the top it will not do it. I thought if I turned off my Num Lock key they might but no go. I have a compaq keyboard with a lot of blue symbols on it. I don't know what it...
Please clarify if this is a PC keyboard and a keyboard on a laptop? If you can, give me the model number of either the keyboard itself or the laptop if it happens to be on a laptop. Many times, if you CAPS lock is engaged, you will see the image on the top part of the key, instead of the number. I need to know what you are looking at before I can help you.
Brian
Dec 23, 2010 | Compaq Keyboard
My computer wont turn on but the low battery keeps blinking (one of the symbol things under the keyboard) and when I try to charge it it wont charge.
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 06, 2010 | Toshiba Computers & Internet
Battery will not charge compaq presario v5000
I would try replacing your ac/adaptor (power plug) before troubleshooting any further. It sounds as if the adaptor is faulty. Check eBay, you can get a replacement for less than 10 dollars.
Sep 20, 2009 | Computers & Internet
I was being nosey hitting buttons and now my laptop is locked
The I button is another one of those unnecessary things PC makers do to try to be more convenient. This one is a programmable button for your favorite or frequently used programs.
Use F8 to boot to Safe mode, then:
Using the Keyboard and Touch Pad In Microsoft® Windows® XP
  1. Click the Start button, and then click Control Panel.
  2. Under Pick a category, click Printers and Other Hardware, click Keyboard, and then click the AccessDirect tab.
  3. Click Help, and follow the instructions.
In Windows 2000
  1. Open the Control Panel, and then double-click the Keyboard icon.
  2. Click the AccessDirect tab in the Keyboard Properties window.
Jun 10, 2009 | Dell Latitude C640 Notebook
How do i use the green symbols on my keyboard
Are the green symbols the alpha/numeric keys? If so, you have to push the num lock key.
Mar 17, 2009 | Acer Computers & Internet
I have dell inspiron 6000 laptop. The laptop keyboard got locked. I can't use the keyboard and if press any key..it works for the function key. On the laptop, the light with lock symbol (9) is on.
When you turn on the laptop, just before Windows starts to load tap the F8 key a couple of times. If you get a menu, choose Last Known Good.
If that does not do it, and the mouse still works fine, go to Start, Programs, Accessories, System Tools and run System Restore.
Choose a date from before the keyboard problem and let it reboot. Should solve the problem.
Honest1abe
Jan 16, 2009 | Computers & Internet
Laptop won't startup
Try removing your battery and then putting it back. If that doesn't work, then either your hard drive is bad or maybe even your motherboard is bad. If you can get into your computer's BIOS, check and see if it will allow you to do a system restore from the BIOS page. As stated above, it is probably that your hard drive is bad.
Sep 06, 2008 | Dell Vostro 1500 Notebook
KDS Valiant 6481C (KN6481CIPT-02) PC Notebook Logo
66 people viewed this question
Top KDS Computers & Internet Experts
Steve Allison
Steve Allison
Marvin
Marvin
Denise
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
