Question about JVC Everio GZ-MG21 Camcorder
Reset how do i set the camcorder to the factory settings ?
  • 928 Answers
To initiate abovementioned preset you can go to menu then press PRESET.
You may also click on the link below to see the source manuall of this unit. Click on Instruction manual in the link below.
http://books.jvcservice.com/booklist.asp?Model=GZ-MG21U
Posted on Nov 22, 2008
3 Suggested Answers
  • 903 Answers
SOURCE: I need to set the camcorder to default settings
For most models, removing the battery pack from the camcorder will restore the default settings; however, some models which contain an EZ Q button, store your settings and removing the battery pack will have no impact on these settings. The Lithium battery maintains the clock function and preset contents of the memory; even if the Battery pack or AC Power adapter is removed. Removing the Lithium Battery along with the Battery pack will restore the default settings.
Posted on Sep 07, 2005
  • 3 Answers
SOURCE: Error Code C:31:23
error c:31:23
http://www.youtube.com/watch?v=VUIN-ygjN_g check this
Posted on Jun 12, 2010
Factory setting sony cx 520
Press the reset switch. if there is no reset switch try to reset it from the Menu functions.
Mar 05, 2013 | Sony HDRCX520 AVCHD Camcorder
My jvc camcorder screen wont work
Sounds like a software issue of your hd camcorder. Which apps do you have loaded? I would try a hard reset. Menu > Settings > SD card and Phone Storage > Factory Reset. If you still have the issue, get the phone swapped out.
Jan 24, 2012 | JVC GR-D850 Mini DV Camcorder
I want to restore my Sony dcr-hc62e camera to factory settings.?
Pleaser press the reset button behind the LCD panel to reset the Camcorder to factory settings..
Jan 15, 2011 | Sony DCR-HC62E Mini DV Camcorder
Can't turn off nightshot on my handycam help!!!
Option 1:
Using the NightShot:
1. First Set the POWER Switch to Camera, Slide NIGHTSHOT to ON.
2. The NIGHTSHOT indicators flash on the screen.
3. To cancel the NightShot mode, Slide NIGHTSHOT to OFF.
Option 2:
1. Let us try to reset the Camcorder and check if it helps to resolve the issue.
2. Locate the RESET button behind the LCD screen of the Camcorder.
3. The Camcorder should be switched ON when you reset the unit. Press the RESET button using a sharp-pointed object.
NOTE: Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.
Good Luck!!!!!!!!!!!!!!!!!!
Sep 13, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
I can't get my camera to record. It says camera recording disabled
just reset the camcorder go to the menu and reset from factory settings
Aug 13, 2009 | Sony Handycam DCR-SR40 Camcorder
I'm trying to clean the heads on my TRV 950, I purchased a cleaning cassette and this error code appreas on the lcd c:31:22
Follow these steps to resolve the issue:
Step 1: Remove the cassette and insert it again , then operate your Camcorder.
Step 2: Try using different cassette.
Step 3: Try resetting the Camcorder.
[Resetting the Camcorder will reset the settings of the Camcorder to the factory settings including date and time. It will not delete any data saved in the Camcorder.]
Please locate the RESET button behind the LCD screen of the Camcorder. Press the RESET button using a sharp-pointed object. The Camcorder should be switched ON when you reset the unit.
Step 4: Try to power reset the Camcorder and check if it helps to resolve the issue. Power Reset the Camcorder by removing the batteries from the Camcorder and inserting it after 1 minute.
Step 5: Service is required.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
Aug 12, 2009 | Sony Handycam DCR-TRV950 Mini DV Digital...
WHEN I RECORD EVERYTHING IS ORANGE, THE CAMERA IS AN EVERIO 35X OPTICAL ZOOM MEMORY CAMCORDER
Lets try a few steps to fix this:
1. Set the Camcorder to Manual
2. Go into the menu Scroll till you get to "Effect"
3. Turn It off
4. Set the camcorder back to "Auto"
If that doesn't help....
1. Go into the menu
2. In the basic settings, scroll till you get to then select "Factory Preset"
>>this will reset the camcorder back to the way it was when you first bought it<<
Let me Know if this helps
***If This has help you, Please don't forget to rate***
Jan 02, 2009 | JVC Everio GZ-MG130 Camcorder
Is there an easy way to reset all settings on camera back to factory default
Here is the link to the user manual for your camcorder if you need it; http://books.jvcservice.com/download/685826248/21964.pdf There does not appear to be a factory settings reset, however in the manual, all the settings and their preset values are listed. You could try removing all multimedia cards, battery, power supply and leaving the unit for around 3 months! (page 11) to discharge the internal memory cell, or if you feel competent to take the camcorder apart, you MAY be able to remove and replace this battery. Unfortunately I think the resets have to all be done individually, or take the camcorder to a service centre to see if they can discharge the internal memory cell - this is probably not a good idea, dependent on the exact tyoe of cell used. Hope this helps some :)
Mar 31, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
My camcorder doesn't work
For Models: CC4252, CC4352, CC4362, CC4392, CC4393 You need to reset your camcorder. Follow these steps: * Remove the power source. * After one minute, gently press the RESET button with a nonmetallic pointed item until you feel a "click." This resets the camcorder to the factory settings and erases the date, time, and custom settings. * Wait for at least one minute after resetting the camcorder to attach a power supply.
Sep 06, 2005 | RCA CC-432 Camcorder
JVC Everio GZ-MG21 Camcorder Logo
1,038 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
