Question about Dell Inspiron 9300 PC Notebook
Memory issues Please help....have an Inspiron 9300 with 1Gb installed RAM. Today I purchased 2x1Gb RAM things to replace the 2x512mb that are in there. When i powered up, all I get is the error LED flashing and the computer won't even power up. Went to DELL support which recommended installing the latest BIOS, which I did to no effect (if anything the computer seems to be lagging now). The RAM I purchsed has the following on it: "1GB DDR2 667Mhz SODIMM". It fits in the slot just fine. Please HELP!!!
  • gmolloy72 Nov 23, 2008
    Thanks for the assistance. Checked it one by one and turns out one of them was faulty. All fixed now!
  • coppercreekr Dec 14, 2008
    When I hit the power button, the power light comes on, and stays on for about 10 sec. and the number lock, caps lock and scroll lock, flash just for an instant. There is no hard drive motion, as well as the fan. I've checked the voltage from the battery and AC power and all check out just fine. further more, if I push the power button twice all lights mentioned before stay lite for 10 seconds. I'm a little stumped at this. There is absolutely no booting at all, and I'm stumped. The best I can think is that maybe it's a failed mother board.
Make sure you purchased the 200-pin SODIMM DDR2 Memory Module for the 9300. For example,
CRUCIAL TECHNOLOGY 2 GB (2 x 1 GB) PC2-6400 200-pin DIMM DDR2 Memory Module Usually Ships Within 24 Hours Manufacturer Part# 114901 Dell Part# A1551576 Technology: DDR2 SDRAM Memory Speed: 800 MHz ( PC2-6400 ) Data Integrity Check: Non-ECC
CRUCIAL TECHNOLOGY 4 GB (2 x 2 GB) PC2-5300 200-pin SODIMM DDR2 Memory Module Usually Ships Within 24 Hours Manufacturer Part# 112805 Dell Part# A1551572 Technology: DDR2 SDRAM Memory Speed: 667 MHz ( PC2-5300 ) Data Integrity Check: Non-ECC
Posted on Nov 22, 2008
  • Dell Master
  • 1,250 Answers
Posted on Nov 09, 2008
Trying to help a buddy upgrade his gateway esx 500s memory as he only has 256mb, is there a limit to how much mem this comp can take or can i install 2GB 2x1GB PC2100 ECC REG MEMORY (CM12872ERX22100DI
Hi Steve Handel II,
Yes that machine has limited RAM capacity, that model can go up to 1GB of RAM total (2x512MB DIMMs.) It takes DDR PC2700, CL=2.5 unbuffered, non-ECC DDR333 memory chips. The good news is you can get them for $10-$20 most anywhere. Like HERE
Good Luck
May 11, 2012 | Computers & Internet
Upgrade to 400 mhz 2x1GB memory
Hello, First thing I would try is to just install one of the new modules in the DDR1 slot and see if it boots. If it does, go into your BIOS (Use the key I believe.) and set the ?Max Memclock (Mhz)? field (Advanced Chipset Features submenu) of the BIOS to 200. Save & Exit and allow it to boot. Shut down the computer and install the second one. Again go into the BIOS and verify it is detecting both. A second thing to try if that does not work is to install the new modules, and before powering up, reset your CMOS using the jumper between the battery and the AGP slot. If the jumper is on the 1st and 2nd pin, put it on the 2nd and 3rd pin for 15 seconds. Then replace it to the original position. NOTE: Make sure the power is OFF and the power cord unplugged when you do this. You should also press and hold the Power button for 5 to 10 seconds to discharge the capacitors in the system. If this still fails to get you going, you may have high density modules which do not work in all motherboards. Did you get the modules from MS Memory Suppliers? When I did a search for your motherboard it only gave me DDR266 PC-2100 DIMMS as compatible. No DDR400 were listed even though they should be backward compatible. Hope this helps. Thanks for using Fixya. Comment back and let me know your results.
Sep 30, 2009 | DFI K8M800-MLVF Motherboard
I can't recognize what specific RAM this motherboard accepts..
Dear sir,
In reply to your post- Generally now a days we use DDR400 RAM(DDR 1) for this type of motherboard.So DDR 400 RAM is More compatible then other RAM,you can use this RAM for your motherboard to obtain good performance.
good luck
Aug 04, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Physical Memory Issue!
What happens after you reboot and check?
Jun 17, 2009 | Dell Inspiron 1521 Notebook
Memory Upgrade Problem
Some of the motherboard DIMMS got limitation. U need to check back the manual. Cannot simply insert different type of speed and capacity on each DIMMs.
Feb 13, 2009 | Acer Aspire™ T180 PC Desktop
Aspire t180 memory problem
check, if you motherboard support 2GB, or else start windows in safe mode with 2GB.
Oct 17, 2008 | Acer Aspire™ T180 PC Desktop
Memory installation
all the DIM's must be of same type and same size to work, otherwise it creates problem, like no boot, boot with lowest memory etc.
There is no problem in your PC, its technical issue you can not use two ore more different type RAM at the same time in a motherborad.
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Doesn't boot with 3Gb of ram....
Your board can only handle 2Gb of total memory.
2 x DDR2 SDRAM DIMMs, Dual Channel DDR2 533/667/800.
Check your manual.
Dec 29, 2007 | Foxconn 6100M2MA-RS2H Motherboard
Dell Inspiron 9300 PC Notebook Logo
244 people viewed this question
Alun Cox
