Question about Xcent XT-100 MP3 Player
Help with mp3 X Cent XT-100
Having just acquired an fairly new XT-100 1gb player I find the CD that comes with it has a manual in Korean language. As I have no idea how the player works I would appreciate any thoughts and assistance so I can get the thing to work. Many thanks
0 characters
1 Points
Getting a user manual in english for a ia65
Try Googling (brand)(ia65)(manual) without parens.
Jul 02, 2016 | MP3 & Digital Media Players
Change OS to English
May 13, 2009 | Cowon System iAUDIO X5L Digital Media...
Language stuck in korean need to change back to english IRIVER ICLIX
scroll each menu entry one by one Look for "english" or "Language" or"영어" Enter when found
Apr 19, 2009 | iRiver E10 Digital Media Player
Sansa clip 1gb mp3 player
You will have to fly blind a bit, but remember that the Spanish word for language is "idioma" and the Spanish word for English is "Ingles" - Here is a link to the user manual that will help you - Sansa does have a Spanish version of the manual if you want to compare. Eventually, you want to find this menu/setting:
Reset All
This will reset the player to its original factory settings.
1. Press Menu to return to the Main Menu.
2. Move to Reset All and select it.
3. Select Save to reset to factory settings or Cancel to stop.
-Tha Mp3 Doctor
Jan 03, 2009 | SanDisk Sansa m240 MP3 Player
I have a new yp-u3 mp3 player but i don't know to turn in on .all the instructions are in the Korean language but i speak english
My new YP-U3 player does not connect when entered into the USB port of the computer, states disconnected, it does charge though. The Samsung Media Studio has been installed and is operating
Jan 02, 2009 | Samsung YP-U3 MP3 Player
Change language
well you just have to setting and language is the fifth opcion get in the languages and just set it to english hope it helps =)
Dec 09, 2008 | SanDisk Sansa c240 MP3 Player
Firmware upgrading the samsung ypp2jar/xac
you need to downgrade to the korean version, and then upgrade. I have done that. Search on google and youtube. Good luck:)
Sep 16, 2008 | Samsung Yepp YP-P2 Digital Media Player
Software - firmware
Read your manual to find out how to change language
Firmware Upgrade:
Nov 25, 2007 | Samsung YP-U3 MP3 Player
Can't SEE Foreign language fonts on my Sansa
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Sep 29, 2007 | SanDisk Sansa E280 MP3 Player
Xcent XT-100 MP3 Player Logo
41 people viewed this question
Top Xcent MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Xcent MP3 and Digital Media Player Expert? Answer questions, earn points and help others
