Question about Sony Handycam CCD-TRV128 Camcorder
Error C:31:32
Sony DCR-TRV22 The error C:31:32 comes up. I have left the door open fo r1 hour, as per manual. I have changed batteries, tapes & same error still appears. When no tape is in - there is no error message.
  • ejmcvt Dec 08, 2007
    I've got the exact same problem with a TRV33
SOURCE: C:31:23 Flashing and viewfinder says "Reinsert the casette"
i know what setmaz says sounds kind of ridiculous; but i got desperate and tried it myself... i can say that as far as i go its a proven method and the camera will start working
Posted on May 14, 2009
  • 169 Answers
SOURCE: Sony DCR-TRV140 CODE
the reel sensor is the problem of your camera...in my job as a technician i always encounter that..it is a poor connection of the sensor to the mainboard..try to clean the contact using only a pencil eraser..
Posted on Apr 13, 2008
SOURCE: Drivers
Check out sony's web site, they are providing all the drivers for there camera's
http://esupport.sony.com/US/perl/swu-download.pl?mdl=DCRTRV22&upd_id=1452&os_id=7
hope this helps
Cheers
Posted on May 04, 2008
SOURCE: error C:31: in Sony DCR-HC42
Same here. When I place cassette into the carriage and snap it shut the servo does not activate to pull the carriage in the rest of the way. Has anyone found any tech solutions for this?
Posted on Aug 18, 2008
  • 85 Answers
SOURCE: My Sony Handycam DCR-HC26 started giving me
the error c:31:23 error pertains to one of the reel (part that turns the tape) is malfunctioning. although you can play back videos, you would definitely have issue w/ recording, rewinding or fast forwarding the tape.what you can do is to turn the camcorder off.remove the battery and ac adapter for at least a minute.insert the battery or reconnect the adapter.you can also try pressing the reset button (located near the top of the speaker, on the panel where lcd screen goes to).make sure cam is on when you do that.if still your getting this problem, service would be needed for your cam.hope this helps :)
Posted on Mar 20, 2010
Error Code C 21:00 continues to flash
Hi, ok now you hold your breath and follow the instructions.. 1. remove all the batteries including the tiny backup battery (usuall seen behind the screen) 2.then hit it very hard.. now insert the batteries and check .. if you dont belive read the link http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR_PC5E_Error_code_C_21.00.html all the best regards sreejith
Jul 13, 2007 | Sony Handycam DCR-TRV530 Digital Camcorder
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
Handycam DCR-TRV22 Records Audion no Video
Need go buy a cleaning tape from any local retailer and play for one minute. Video should comes back up.
May 10, 2010 | Sony Handycam DCR-TRV22 Mini DV Digital...
How do i take out the tape without damaging it or the tape please
If the door is stuck shut and won't open with button, your only choice is to pry it open with screwdriver.
Jul 07, 2009 | Sony Handycam DCR-TRV22 Mini DV Digital...
Sony Handycam DCR-TRV22 camera
HI! THE ERROR CODE C:32:10 IS A TAPE LOADING ERROR. IS A TAPE STUCK IN THE CAMERA? IF IT IS OR NOT FOLLOW THE FOLLOWING INSTRUCTIONS TO CLEAR THE CODE!
1.UNPLUG THE AC CORD FROM CAMERA.
2.REMOVE FAT BATTERY.
3. REMOVE SLIM BATTERY, FROM UNDER THE LCD-ABOUT THE SIZE OF NICKEL.
4. WAIT 2 MINUTES.
5.PLUG THE AC TO THE CAMERA.
6. FLIP THE CAMERA TO THE VTR MODE.
7. TAPE SHOULD EJECT AND THE CODE SHOULD CLEAR.
OK? HOPE THIS SOLVES YOUR PROBLEM. DON'T KNOW IF THIS WAS ALL OF YOUR PROBLEM, BUT IT SHOULD SOLVE THE ERROR. IF YOU NEED HELP REPLY TO:
ARCLIGHT1217
Nov 06, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
DCR TRV22 does not showup initial screen
What is the message/ error code flashing in your camera?
Jun 25, 2008 | Sony Handycam DCR-TRV22 Mini DV Digital...
Trouble using dcr-trv6 mini dv camcorder
This is a common failure in this model and unfortunately will not be resolved without a qualified servicer. The error code indicates a message for lack of reel motion. Most often it is an electronic connection problem and not an actual reel problem. Good luck, magic seadog
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Receiving error C:31:42. Removed tape, battery, and left opened, but still get error
How long did you leave it to dry? I had a similar problem and had to leave out my camera for more than a day before the problem was resolved.
Jun 19, 2007 | Sony Handycam DCR-TRV330 Digital Camcorder
Reinsert cassette error... cannot record via tape
What error message is it giving to you ?? as this will be a good indication of fault.You have tried all the usual things to try by the sounds of things,
May 14, 2007 | Sony Handycam DCR-HC46 Mini DV Digital...
Sony Handycam CCD-TRV128 Camcorder Logo
990 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
