Question about 2wire (1000-400108-001) Router
2Wire router keeps dropping connection
Each time around this time of year my broadband connection starts dropping the router then reboots and alls ok for an indefinite time but then it drops again I have changed all cables & have used another 2wire router but that does the same so I'm think I'm loosing bandwith or noise from my isp but after having this out with them numerous times in the past with no luck resolving the issue what is the best option here?
Cheers Bill
  • billathome65 Nov 09, 2008
    Hi they have run tests for this issue on a number of occasions and stated all's fine and sent out a replacement router I've had 6 LOL In the last hour the system has dropped around 20 times intact as I'm writing this the router has just reset this is actually the 2nd router today and and new leads.
    They have increesed the gain in the past to no avail.
    If it is the router then this is an issue with all this model since as I said they have sent 6 out with all the same problem.
    Looks like it's gonna have to be a total new / different router and a call to the ISP for the settup info.
    Cheers Bill
    New Friend:
  • 5 Answers
Enter you ISP address in the search bar to get to your 2 wire settings. Go to home network and then settings. Then click on modem settings. Change it from 11g to 11b. Had this problem for 2 years. No problems since.
Posted on Jan 22, 2014
  • Carol Reppert Wirz
    Carol Reppert Wirz Jan 22, 2014
    This worked for me. Put your ISP address in the search bar to get to your 2 wire settings....then to home network...and then to modem settings. Change to 11b. I had problems for 2 years and non since.
Its the heat. the heat does something to the lines, causing the connection to drop.
Posted on Jun 06, 2010
Hi nothing close apart from comp. This is a router/modem I have had this issue on other systems to.
It just seems that this usually happens around this time of year this???? don't know if it's just a coincidence??? Chances are this will sort itself out again but it's just so strange and frustrating.
Regards
Posted on Nov 09, 2008
If you try to change the router and getting same problem, i think you need to isolate it first without the router because this is not the issue, by the way did you ask your ISP to run a line test? what is the result? have you try to change the modem? my first suspect is the modem.
  • Anonymous Nov 09, 2008
    im sorry i assume before that your using a separate device modem--->router--->yourpc
    can you clear things out to me, are you using a router modem?
    so your connection is router.modem--->your computer ?
    have you tried to use a different computer to make sure theres no problem on your end?
    make sure also there's no device close to your modem or router that will interfere it's signal like example speaker,microwaveoven,power supply.
  • Anonymous Nov 12, 2008
    hmm. by the way hows your weather there? sorry for the stupid queston but weather can also be the cause of this.
Power outage unable to connect wirelessly e1000
Make sure power is back up. Check both ISP modem and router indicator lights are normal. Test ISP connection with cable. If all is still OK then use the reset button in the back of the router.
FYI - ISP modem might also have a reset. I had to this for TV even though everything said OK.
Aug 29, 2012 | Cisco Linksys E1000 WirelessN Broadband...
I have a lynksys wireless-g broadband router WRT54GS. Ever since I bought it, after turning it on and been connected it drops the connecton after a short while. The only solution is to reset the router...
I don't have a solution for you, but this workaround might be of some help. From what you stated it sounds like you are turning off your router when you turn off your computer. Why turn power off your router (or high speed modem) at all? I leave mine on 24/7 - they don't consume hardly any power and they don't have to initialize and "lock on" to a DSL signal every time you turn them on.
As you know, if you have a constant input signal, your router shold not drop it. I recommend that you you goto http://www.linksys.com/support and enter the model number of you router. Linksys offers live chat support and they should be able to suppy you a permanent fix to this problem
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jan 31, 2011 | Linksys Wireless-G Broadband Router
The computer operating on the wireless link loses its connection.
Power surge is one reason that could cause this problem. It would help if you will connect your router to a surge protector and not directly to the power outlet. You can also update the firmware of the router if it is possible.
Jun 08, 2010 | Belkin (F5D7230-4) Router (587009)
We have BT broadband. When we occasionally have to reset the router, everything except the 2 Dell Dimension 5150 desktops works via wireless. They refuse to reconnect. All the other Desktops / laptops work...
Not sure exactly what your hardware setup is, but I would reboot the broadband router, then reboot the wireless router. Everything should come up clean, but give it at least 5 min. To help connect after reboots, you can choose "repair" from the wireless icon in the system tray (XP?) or renew your IP address. Start --> Run... and type ipconfig /renew
Hope this helps!
If so, please leave a rating!
Mar 11, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Belkin Wireless G router not reachable
routers go for 2 years, and then they stopped.
buy a new one
unaasp192
Jan 18, 2010 | Linksys Wireless-G Broadband Router
MN-700 needs constant re-setting
probably overheating u may need to get a new one. :(
May 24, 2009 | Microsoft Broadband Networking MN-700...
Setting up for broadband
First, you might want to check with Plusnet the login information and the type of the authentication they have. Secondly, setup your router, login to your router using a web browser. Type 10.1.1.1 in the address bar and press enter key.Login using the default setting username 'admin' and password 'admin'.
Click on Home tab and then on WAN on the left side of the screen.Select PPPoE/PPPoA option.Under Connection Type select 'PPPoE LLC' in the drop-down menu.Enter username and your password.Please check with your provider if not sure again.
If you have connection with static IP address, you do not have to specify the IP settings on the router: the router will be getting the same IP from your ISP every time it connects.Click on Apply. To save the settings into the router's memory go to Tools > [System] > Save and Reboot.Give the router a minute or two to reboot and reconnect.
Lastly, Restart your computer and you should be able to access the Internet.You do not have to run any login client on any of your computers because your router logs to your ISP automatically.
or check this URL;
ftp://files.dlink.com.au/products/DSL-502T-GenII/Manuals/DSL-502T_GenII_Manual.pdf
Jun 12, 2008 | Computers & Internet
Dropping wireless connection
The problem may not be with your router. I had a situation a year ago with the modem dropping the signal everyday. I spent hours on the phone with verizon tech support to no avail. They sent someone out to my home and he put a filter on the main line coming into the house which didn't resolve the issue. Then verizon insisted the modem was bad so they sent me an actiontec. Turns out that the problem had nothing to do with me. They try to squeeze as much bandwith at their switching stations as they can. They switched me over to another hub and viola no more problem.
May 20, 2008 | Actiontec GT704WG Wireless Router...
2wire dropping xp pc
hello!
you may try this and see if this help solve your problem
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire (1000-400108-001) Router Logo
2,254 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
